setting timing on 98 12 v questions!
Old 04-20-2007, 07:53 AM
oldblues's Avatar
Question setting timing on 98 12 v questions!
hi
i am going to do the kdp sooooo !
while i am in there i was thinking of setting the timing at 16 deg .
factory is suppose to be 14 . truck runs fine now .
would i notice any improvment by moving it to 16 ?
i see a lot of post on timing slipping , how do you prevent this from happening ?
what tools are a must have to do this job ?
i have english dial indacator but not a metric one , must i have a metric one ? how much travel must it have ?
what is the correct procdure for setting the timing ?
thank you !
Old 04-20-2007, 09:07 AM
plow's Avatar
http://dodgeram.info/tsb/1994/18-10-94a.htm heres a little info.
Old 04-20-2007, 03:33 PM
Muddin_dude06's Avatar
You can use an SAE dial, you just have to convert the measurements. When I did mine the other day my truck ran fine but I was only at 3mm of lift which is 8-10*. I set mine to 18* which is 6mm lift = .362". Use electronic parts cleaner or brake cleaner to spray the pump shaft down with to clean off oil residue, that will help keep your truck from slipping the timing after you put it all back together.
Old 04-20-2007, 09:45 PM
oldblues's Avatar
hi
how did you know that you wanted to set timing to 18 deg?
mine factory is suposed to be 14 so i was going to go to 16 ?
thank you !
SilverRam3500
08-24-2007 09:24 PM
BigBully
20
02-22-2007 09:37 PM
Dave88LX
12-04-2006 08:25 AM
West Coast
10-11-2006 10:33 AM
Ram of Steel
08-14-2006 02:20 AM
Quick Reply: setting timing on 98 12 v questions!
