In search of more low end power
Old 02-21-2008, 07:33 PM
Lundee's Avatar
Ok I've got what it says in my sig along w/ a3k gsk and softer afc spring sitting on the self to go in this weekend. She's a rocket ship from the mid to the top but, the low end is sluggish. Hopefully my timing will be done this weekend as well but, will let the buddy do his first any help would be great I"m new to this 12v game.
Old 02-21-2008, 07:38 PM
aksparkey01's Avatar
is the fuel plate stock? if so swap it with a 100 and crank the starwheel out. that should help.
Old 02-21-2008, 08:36 PM
Lundee's Avatar
#4 plate wheel full forward sorry I forgot to put that in my sig.
Old 02-21-2008, 10:32 PM
what is low end for you. i have not ran that turbo but i can only assume that it wont spool up untill arround 2k rpm. I really like the 100 plate i would recomend grinding it to that profile. if the afc housing and plate arent full foreward try sliding them all the way foreward. maby some one will chime in that has run that charger but i bet that it is just a little slow to spool up. some more fuel should help that a little bit. so i would say grind the plate to 100, and when you get the chance upgrade to the 4k gsk and valve springs. and a timing bump will help out, probally 15.5* without head studs. hope that helps
cali4niacoalrlr
04-01-2014 09:22 AM
LanceD
10-05-2010 05:00 AM
woodrep
09-06-2007 07:46 PM
RAMRODD
0
05-23-2006 10:08 PM
spitzair
01-24-2006 03:42 PM
Quick Reply: In search of more low end power
