Scored!!Normal??
Old 05-20-2008, 10:39 PM
06RAM2500's Avatar
Scored!!Normal??
Flipped some valve brides around, and noticed this.
Hopefully it's not a taste of whats yet to arrive.
Old 05-20-2008, 10:48 PM
Muted User
Sprinter17's Avatar
Sorry, but that doesn't look good.
Old 05-20-2008, 11:03 PM
06RAM2500's Avatar
If my rockers look like that, I don't want to see the bottom end!
Old 05-20-2008, 11:56 PM
N.Johnson's Avatar
What lube oil are you running? How long between changes? Looks like scoring and spaling.....bad. If you got a micrometer check the inside ID's at 9-3 clock and compare 12-6 clock. That ain't right, might be a manufacture machining defect. I have been told that bridges shouldn't be swapped around.
Old 05-21-2008, 03:52 AM
annabelle's Avatar
Idle much?
Old 05-21-2008, 07:50 AM
06RAM2500's Avatar
Been running Valvoline Prem. Blue the last 10,000 miles, Royal Purple for 25000, then Amsoil for the first 30k. Idle probably 4-6 hrs a week.
Old 05-21-2008, 09:19 AM
jrussell's Avatar
If just idling caused that, then everyone would have issues since all of our trucks idle for some amount of time. Idling too much is only harmful if the engine isn't up to operating temp...and that causes piston/ring/cylinder damage not rocker damage.
Old 05-21-2008, 10:15 AM
PourinDiesel's Avatar
I think its kind of nature of the beast. If the rockers work smoothly then there is nothing to worry about.
Old 05-21-2008, 10:32 AM
Muted User
Sprinter17's Avatar
I'd be trying to get some of the high spots down with some scotchbrite abrasive before I ran it again.
Old 05-21-2008, 02:39 PM
annabelle's Avatar
No, I don't idle except in high idle mode for just that reason. It's not that uncommon. Idleing for prolonged peroids is a costly myth.
Old 05-21-2008, 09:19 PM
CG98x's Avatar
Mine had 115000 when I pulled the head and Mine didn't look like that
20
03-07-2007 03:20 PM
iker42
11-30-2006 07:29 PM
AllPlay
17
06-10-2006 04:29 PM
haloman
02-27-2006 06:26 PM
Proram
08-24-2004 05:48 AM
Quick Reply: Scored!!Normal??
