Score for me
Old 12-22-2006, 09:50 PM
91.5CTDBanks's Avatar
Score for me
I looked in the local I-wisher paper today and noticed some ford bullethole wheels and tires forsale. I jump fast and picked them up with Goodyear RT-S 265 75 R16 tires that have 70% tread left....for $150 including lugnuts.
Old 12-22-2006, 09:52 PM
Good find!
Old 12-23-2006, 11:51 AM
NoSparkplugs's Avatar
Very nice find. I might be looking for a set of those in the spring. What years of Ford trucks did those rims come off of? A little bit of aluminum cleaner, some polish and they'd be all nice and sparkly .
Old 12-23-2006, 12:00 PM
89dieselkong's Avatar
Nice score!! Those are good lookin' rims
Old 12-23-2006, 12:06 PM
boiler-rat's Avatar
Yep, pat yourself on the back. You done good!
Old 12-24-2006, 05:22 AM
KAyers's Avatar
Location: Springtown Texas, the land of MILFs and Honeys
Originally Posted by NoSparkplugs
... What years of Ford trucks did those rims come off of? ... .
Those are aftermarket wheels in the picture. The factory wheels didn't have the simulated rivets around them.
I have a set of the Factory Ford wheels for my truck. They came off of 94-97 trucks and vans even later. You cannot use 1999 and newer Ford wheels though. By the way, the factory Ford wheels are genuine Alcoa wheels. Very good quality. I had to give 300 for my set with no tires or nuts.
Old 12-24-2006, 06:59 AM
Ok, I do not know much about them. I have found the ford lug nuts I have for them will not fit a Dodge, the stud for Dodge's is smaller.
Old 12-24-2006, 07:59 AM
KAyers's Avatar
You scored a real deal, no doubt. I wasn't trying to imply any different. I was just trying to make sure the other fellow didn't get confused about factory and aftermarket wheels.
Old 12-24-2006, 08:04 AM
^ Thanks, no harm done. I like to know as much as possible about them too.
Old 12-24-2006, 12:00 PM
Winr's Avatar
[QUOTE=KAyers;1266125]Those are aftermarket wheels in the picture. The factory wheels didn't have the simulated rivets around them.
QUOTE]
Better yet...
Old 01-16-2007, 04:42 PM
Ok, this is steep. I have found out I have American Racing Outlaw II wheels, good. It has taken me 3 weeks to find the topline products Duplex lugnut. Stockton Wheels in CA has them and wants $120 shipped for 32 of them .
So I will just have to look local. The topline spec for the lugnut is 1" shank length, 0.73" shank width and 1/2 20 thread.
Old 01-16-2007, 10:14 PM
PapeCAT's Avatar
Yes the Ford Aluminum wheels are made by alcoa and they still offer them on the Alcoa website. You can see pictures of them there. I paid 270 for a set of 4 with tires and no lug nuts.
Old 01-16-2007, 11:12 PM
JimmieD's Avatar
You might want to give a holler at JEG's or Summit. They can get stuff that isn't shown on the net or in their catalogues.
One important factor is the flare or 'hub' on the bottom of the lug nut, that it be the correct diameter to safely retain the wheel per factory spec. Might call American Racing on that. Also Dorman Fasteners is well known to stock some really hard to find lug nuts and studs and most auto parts stores, at least NAPA and Carquest, can access Dorman for a search. 1/2" X 20 is just a fine thread instead of the more common 1/2" X 13 SAE thread.
Old 01-16-2007, 11:34 PM
JimmieD's Avatar
The nut described at the link is as close to your posted specification as I could find:
https://www.dormanproducts.com/cgi-b...st=1530:1246:0
You'll have to make sure that the 60 degree flare is correct for your wheels.
Old 01-17-2007, 04:43 AM
Thanks for the help JimmyD. I have called Jegs/Summit but they do not have anything. The lugnuts I need are lug-centric and have a 1" shank that sticks into the wheel lug hole.
This is the link, http://www.tradeunion.com/ToplinePro...lugsshank.html down in the middle is a duplex mag. That is the one I need.
Quick Reply: Score for me
