SB dd + smarty= awesome
Old 01-11-2008, 01:06 PM
BBarnett's Avatar
I got the 3250 in and it is bad. Slight rattle in neutral, but not bad. Slightly heavier pedal pressure but not bad either....
With the smarty on 9 and the dr.p box on 100 this truck will flat out get it, cant waith to see what my phat shaft does....
Peter at southbend does a jam up job, the fit and finish of his clutches are top notch, a little pricy but everyone knows, you get what you pay for...
I cant wait to try the wild thing on the smarty...
Brian
Old 01-11-2008, 02:10 PM
53 willys's Avatar
I'm jealous!!! I need a clutch BAD!!
Old 01-11-2008, 02:32 PM
rstone's Avatar
That sounds good brain I am going to have to hurry and come down and check it out one day
Old 01-11-2008, 03:40 PM
BBarnett's Avatar
I cant believe what a good clutch will do, can you say 33' s braking loose in 3rd...
This clutch rocks. I just need to get used to it... Is the double disk southbends suppose to rattle in neutral? If I bring the rpms up to 1000-1100 it quits rattle..
Old 01-11-2008, 04:34 PM
snoyes's Avatar
yep,
The SBC DD will rattle in neutral. Adding RPm seems to make it go away. You can add a harmonic balancer, the Fluidampr (pricey) which will eliminate the rattle.
Old 01-11-2008, 05:46 PM
wap
wap's Avatar
That clutch will do more than break 33s loose in 3rd, I can break mine loose in 4th with dual 34s, it can take it.
About the damper eliminateing the rattle... it didnt on my truck.
Old 01-11-2008, 05:56 PM
Speed Shift's Avatar
Brian
So your saying you like it?
Old 01-11-2008, 06:47 PM
SlowSixSpeed's Avatar
Did it "not get it" with the stock clutch?
Ive needed a stronger clutch for 2 years now but it only slips if I got WOT before the boost comes on but 90% of the time it holds and pulls hard.
So does it honestly get it better or just doesnt slip?
Old 01-11-2008, 07:51 PM
jmccart's Avatar
The DD 3250 is a sweet one.
Old 01-12-2008, 06:58 AM
wap
wap's Avatar
It doesnt slip. If you cant put the power to the ground you dont really know what you truck can do, if yours is holding for you a new clutch probably wont help you much but I couldnt runn anything over 3/2 on my tst without killin my clutch on a WOT run.
JKE
10-07-2003 10:30 AM
DarrellB
34
10-05-2003 06:45 PM
muddymess
12-17-2002 06:12 PM
drecu
10-16-2002 02:51 PM
Quick Reply: SB dd + smarty= awesome
