sagging front
Old Mar 1, 2004 | 08:10 PM
loch's Avatar
sagging front
Hey does anyone know a way to raise the front end other than springs ? i put a set on it a year ago and its went back to sagging again. Perhaps air bags ?
Old Mar 1, 2004 | 08:18 PM
carl20320's Avatar
2WD or 4WD? Which springs did you put on?
Carl
Old Mar 1, 2004 | 11:14 PM
loch's Avatar
its a 2wd 89 model 3500 dually,the springs came from a dealer ,sposed to be heavy duty
Old Mar 2, 2004 | 01:57 AM
carl20320's Avatar
That's the problem! MOOG sells an aftermarket spring that is the super heavy duty and fixes that sag. It actually lifts the front end up so that the truck is pretty much level. I have some pics that I will be getting on here real soon for some other folks (I have not forgot). Installing them were the single best non-engine improvement i have done to my truck. The spring is part number 7226S. The normal spring is the 7226. There is about a 500# capacity difference (if my failing memory remembers correctly) between the two springs. I had them ordered through a local auto parts store. My truck had also have the heavy duty factory springs installed by the previous owner and they sagged from the day I got the truck.
Carl
Old Mar 2, 2004 | 08:24 AM
Redleg's Avatar
Don't use blocks up front, it's not safe, and most places, illegal. To get a lift from air bags, you'll get a stiffer ride. They're just to releave your suspension and level you out when under load.
Old Mar 2, 2004 | 05:45 PM
loch's Avatar
thanks for the info ill look into the moog springs
holeshot440
Apr 15, 2007 05:59 AM
Santaclaus
Apr 2, 2007 09:07 AM
dutchman
Aug 5, 2006 10:13 PM
Idaho Guy
17
Apr 13, 2005 07:21 AM
MARKY MARK
Dec 29, 2002 09:17 PM
