S400 specs??
Old 04-05-2006, 08:04 PM
casper_cobra's Avatar
S400 specs??
what are common inlet and outlet sizes? i just bought one and wondering if theres away to ID it from the tag or not? thanks
Old 04-05-2006, 10:12 PM
strokethis600's Avatar
Call Haisley Machine. The only other thing is that with your set up you would want the 80mm exhaust housing. you can also get them in I believe 110,120,130? I also think that they all have a three inch inducer so if you are planning in pulling in the street class you will have to get a shim from haisleys to get it down to the 2.8 limit.
Old 04-06-2006, 04:45 AM
24valvepuller's Avatar
The s-400 I ran last year had a 2.5 compressor wheel with a 110 exh. housing. I wouildn't go any bigger exh. housing. Mine didn't lite until 2500 rpm with almost an identicle set-up to what you are running. With a torque enhancer D box I only got 43-45 lbs of boost, never had a problem with the HG at that level
Old 04-08-2006, 12:05 AM
thanks for the info...i plan on going back to haisleys next weekend again when i get it and see what van has to say about it...what injectors were you running 24vpuller?
Old 04-09-2006, 08:27 AM
same as you, I don't believe they were big enough though. Haisley's charger has a 2.8 wheel and lites a little easier. A guy back here runs one with an auto and a Redline box with the same injectors as you and he does really well
Old 04-10-2006, 11:45 AM
so what do you think about the 80 housing on the street as a single? probably be too laggy, and i rarely ever pull trailers. i dont know anything about it yet, i bought it off ebay so it may even need a rebuild
Old 04-10-2006, 06:32 PM
I have driven mine around alot with the s-400 and it is laggy and smokey until 2500 rpm with the VP The smaller housing would definitely help
Old 04-10-2006, 08:37 PM
awesome well i cant wait to get it, ill take pics and put them on the on here this weekend
Sixpack73
15
07-17-2009 07:31 PM
TxDiesel007
01-27-2007 08:06 AM
06RAMCTD
0
12-19-2006 04:15 PM
LanceD
07-04-2005 04:59 PM
signature600
02-04-2005 08:58 AM
Quick Reply: S400 specs??
