S300G shaft play
Old 01-24-2008, 01:09 PM
Txwelder's Avatar
S300G shaft play
Just got my turbo in the mail. Bought it off e-bay and blah blah blah I know, could have ended up with a dud. Anyhow, it has some endplay in the shaft. More than what my HX35 has. Measure with a dial indicator it is about .030". Is that acceptable or out of limits to run on the truck. Guy that sold it said he didnt like how it ran on his 01 24V but that it only had a couple thousand miles on it. It looks to be in great shape and not worn out but I am concerned with the play in the shaft. There is no evidence of the compressor making contact with the housing so that is reassuring but still want something definate before it is installed. Thanks in advance.
Old 01-24-2008, 01:14 PM
dieselman2300's Avatar
Yeah, that sound about right. When I got my HTT 62/14 I tought I got a bunk turbo, with all of the side to side play in it. I called them and they told me they are just setup looser, than a HX35.
Old 01-24-2008, 01:20 PM
Redliner's Avatar
Mine was the same way. Probably got it off the same guy as you did. Dont worry about it mines still runnin fine.
JD730's Avatar
End play or side to side play? If you have .030" end play you got some problems. The spec on a HX35 is (.001-.005") end play and (.013-.020") side to side play, holset calls it radial movement.
Old 01-24-2008, 01:34 PM
Txwelder's Avatar
So it is side to side play. There is no in and out play. Just looks crazy how loose it is. Scared to put it on like that with the HX35 being so tight after 175k miles. Dont want to have to do a turbo swap on the side of the road.
Old 01-24-2008, 01:38 PM
JD730's Avatar
I would call HTT or II and ask them what to expect with the side to side play, knowing they set them up a little looser. .030" might be ok if its one they setup.
Old 01-24-2008, 02:18 PM
Txwelder's Avatar
HTT said that some units come from the factory with .025 side to side play and that they are going to be relatively slopy compared to older style turbos. I told him Im at about .030 and he said that is on the outer limit of what is acceptable but that as long as I have no in and out play and no contact between the compressor and the housing I should be ok.
Old 01-24-2008, 02:30 PM
pwrtripls1's Avatar
put some oil through the bearings and measure it again. If its sat dry for awhile it will show more movement than with an oil film.
Old 01-24-2008, 03:35 PM
Txwelder's Avatar
It has been dry for at least a couple weeks so that would probably have some impact on it. Thanks.
Old 01-24-2008, 04:18 PM
Mountaineer's Avatar
Sounds pretty scary to me. I don't know if you should use it or not.
How much you want for it ?
Old 01-24-2008, 07:42 PM
GFB
GFB's Avatar
I'll offer $2 more than what he offers.
Old 01-24-2008, 08:43 PM
dodge00's Avatar
Txwelder let me know if you are interested in selling your HX35.
Old 01-25-2008, 06:10 AM
Txwelder's Avatar
I am interested in selling it, currently have a guy local interested and I have a classifieds add on this site. If it falls through local then I will let you know. Dont think Im selling the BW unit. As hard as it is to determine tone and intent while reading text, I assume you are being sarcastic.
Old 01-26-2008, 07:19 PM
Your assumption was correct.
Old 01-28-2008, 05:55 AM
Txwelder's Avatar
TUrbo went on, absolutely no problems with the turbo. Install was a PITA. Had to remove wastegate as the oil return line wouldnt go in with it in there. Made 396/783 on the Dyno.
4x4dually
01-05-2007 01:07 PM
BigBully
11-27-2006 08:47 AM
FDPOWER
05-27-2006 03:02 PM
NMCTD
03-29-2006 12:38 PM
SuperDave4x4
22
11-16-2005 06:10 PM
Quick Reply: S300G shaft play
