rust (?) under the paint
Old 08-04-2005, 06:46 AM
thatguy's Avatar
While washing and waxing my truck I noticed what appears to be rock chips in the paint. But on closer examination, they actually appear to be UNDER the clear coat and it looks a brown/rust like color. You do not feel anything when you run your finger of them, but you can see it.
Anyone know what this is?/
thanks
brian
Old 08-04-2005, 07:57 AM
Mopar1973man's Avatar
Be aware... DC used a red-oxide primer paint that looks like rust (in some cases).Blistered and raised I would say it more rust than primer.
Old 08-04-2005, 01:39 PM
thatguy's Avatar
Ok.. that makes sense that it could be the primer.. When you run your fingers over the spot it is smooth, you feel nothing..
Any ideas on what causes this? How to keep it from happening?
thanks
Brian
Old 08-04-2005, 06:27 PM
There really isn't too much you can do about it but fill in with touch up paint.
Ways to keep it from happening...
Don't drive on gravel roads or fresh chip coating....
Accelerate really slow and drive slow...
Buy tires with very little tread pattern...
It's a truck drive it and enjoy it... Mine if full of rock chips, scratches, dings... This is what I bought it for to work it!
If you have tires like mine (in photo gallery) you will pick up anything and everything and throw it!
Old 08-05-2005, 06:54 AM
thatguy's Avatar
These are not rock chips (i have plenty of those and keep filling them in with paint).. These look like rusting rock chips, put there is no dent/ding and they are smooth to the touch... The clearcoat is not damaged at all..
Old 08-05-2005, 07:53 AM
Is this on the bottom of the fenders?
Where is this at?
Old 08-07-2005, 09:09 AM
thatguy's Avatar
These are a couple the driver side door near the window and a couple on the bed at the top as well.
thanks
b
Old 08-07-2005, 11:13 AM
Those are unusual places to find rust. I figure it would be the bottom of the doors/bed. Where the rocks chip it the most.
I don't know what to say...
But to watch and see if it grows at all... If it is rust it will start to blister in time. If its a clear coated rock chip... Then it will remain the same forever...
Old 08-08-2005, 09:59 PM
Registered
blackdiesel's Avatar
in 999 cases out of 1000 rust will 'bubble' and you will be able to feel it.
Old 08-10-2005, 09:27 PM
Dshiftff's Avatar
Sounds like rail dust to me.
12ValverDave
21
07-30-2007 11:31 AM
ShawnQ
12-30-2006 06:36 PM
cheff
02-25-2006 12:19 PM
steelydan
13
02-04-2005 08:21 AM
Dodgezilla
06-09-2003 04:33 AM
Quick Reply: rust (?) under the paint
