running a little rough
Old 07-07-2007, 06:30 PM
440forPOWER's Avatar
Hello, Lately my 93 has a little shake to it when taking off slow. (not the normal diesel boogie) Nothing major but it seems to be running a little rough mainly off idle. (or at least thats when I notice it) So my ? is what are the signs of dirty injectors or the injector pump starting to go? Again its really hard to notice but I know it wasnt there before. It starts fine and seems to run ok. Just looking to prevent a problem. THANKS
Old 07-07-2007, 08:17 PM
mullishacrew's Avatar
did you take the fuel filter out and take a look inside and see if it's got dirt in there? mine just needed a fuel filter luckly, so take a look at that
Old 07-07-2007, 11:50 PM
dpuckett's Avatar
Run a 2-4X dose of injector cleaner through the tank. Rough running is one sign of injectors needing work.
DP
Old 07-08-2007, 07:22 AM
Auto or manual? Is it an engine miss or a driveline thing?
Old 07-09-2007, 09:41 AM
Hello, its an auto and it seems to be worse on the first start up in the morning. It does feel a little like a misfire on a gasoline engine. But today it really didnt seem to be there. I changed the fuel filter not to long ago but I think it might be due again. I'll try that and see if it helps. On the injector cleaner what brand do you suggest? Thanks
Old 07-09-2007, 12:30 PM
Micaiahfied's Avatar
if you can get to a T/A truckstop and get some howe's meaner cleaner it's pretty good stuff.
Old 07-09-2007, 07:39 PM
SPINPOSI's Avatar
Mine misses in the morning for a bout a block then clears up.
(I blame this on air getting into the lines overnight, If it sits for a week it dies a mile down the road and I need to crack the injector lines to get it to run again)
8mpg
17
04-24-2006 10:05 PM
JARHEAD
11-19-2004 11:57 PM
Mexstan
03-31-2003 02:37 PM
Quick Reply: running a little rough
