Run engine with no trans?
Old 04-13-2007, 12:32 PM
mvanhelden's Avatar
I'm putting a south bend clutch in, while i was at it i installed a new crank seal, would it be ok to run the engine witht just the flywheel and no clutch/trans? i want to set the high idle for a while to see if the seal leaks before i assemble everything just to be safe. would it throw the engine off balance or anything? should i support the back of the motor?
Old 04-13-2007, 12:46 PM
dodgezilla04's Avatar
without very securely attaching that 930 or so # motor to the frame, I wouldnt do it. when she fires off, she'll torque over and when shutting down. i dont recommend it.
it will not affect balance of the motor, you just dont have 33% of the engine support in the truck.
Old 04-14-2007, 02:24 PM
mvanhelden's Avatar
would there be anything that would get streached too tight or anything becuase of the engine moving around? Just hate to ruin a 900 dollar clutch in a hundred miles because of a defective seal.
Old 04-14-2007, 08:13 PM
OutlawR6's Avatar
Do not start your engine without the trans and all supports to hold it in place. These things rock around pretty good when shut down. I would be worried about the engine beating aginst one of the fenders or other parts in the engine bay.
Old 04-14-2007, 08:42 PM
Rsquared28's Avatar
The engine is not going to beat around the fenders.
It may rock back and forth because of the mid-engine mounted engine mounts. I would set up jack stands at the front and rear of the engine and let it rip. As for clearences, the fan and shroud would be my biggest concern.
Anytime I replace a rear crank seal, I always run the engine and drop the flywheel back down to check the deal.
Old 04-14-2007, 08:56 PM
johnh's Avatar
i have never heard of running an engine to check a new rear seal...i have re built hunderds of engines ,never had one leak while under warranty
Old 04-14-2007, 09:41 PM
Rsquared28's Avatar
While good technicians rarely screw up crank seals, I have had to replace seals for a lot of young inexperienced techs. It has been standard operating procedure to run engines with no tranny in several shop I have worked at. Let the engine run for 15 - 20 minutes, grab a cup of coffee, whatever.
This is a lot easier than having to deal with an angry customer, or pulling the transmission back out later on.
Old 04-14-2007, 10:11 PM
TheBigNasty's Avatar
I have bought brand new bad parts. Just because it is new doesn't gurantee it is not defective.
Old 04-14-2007, 11:56 PM
johnh's Avatar
of course i realize things can change with time, i retired from automotive repair in 1986 but like i said, i never heard of it
Old 04-15-2007, 01:56 AM
mvanhelden's Avatar
It's not if i installed it right but being i purchased the seal at kragen makes me worry, it's a felpro seal, are those good seals? But if by some chance it's defective, then goes a weekend on pulling the tranny out, and 900 bucks because of an oil contaminated clutch disk. So nobody's ran there dodge with no trans?
90 power ram
10-06-2011 08:04 PM
Totallyrad
09-25-2010 11:15 PM
ppsi
13
04-13-2004 03:49 PM
Quick Reply: Run engine with no trans?
