RPM Spike on forced downshift
Old 06-09-2010, 07:04 PM
Roy E. Friis's Avatar
I have a 2005 Dodge Ram 2500 Cummins quad cab 2WD 48RE transmission. The RPM spikes from around 1700 to 2800 when I force the shift from OD to 3rd in Tow/Haul mode. This happens when I am pulling around 12,000 lbs or empty. Is this normal? A mechanic friend seems to think this could be damaging to the tranny and drivetrain.
Roy
Old 06-10-2010, 12:53 AM
Spooler's Avatar
You should be O.K. The only thing to really watch is overrevving the engine. You will drop a valve seat/valve if you do. If you are doing this to slow down, get an exhaust brake, you won't have to be shifting it to stay at speed.
Old 06-10-2010, 10:46 AM
DTR Detective
steelblitzkrieg's Avatar
The 05's still only had O/D lock-out as Tow/Haul, no? So you're downshifting which raises RPM's.
CarBizIndio
05-01-2008 11:13 AM
Dojman
05-16-2006 03:37 PM
zack_76401
15
05-31-2004 12:46 PM
fishin fever
02-22-2004 08:32 PM
Quick Reply: RPM Spike on forced downshift
