Rough Idle @ 900 RPM Only – Please Help!
Old 11-29-2009, 08:35 PM
Al Ex's Avatar
Got home from a trip today, when I pulled into the driveway I noticed the engine had a rough idle between 800 - 900 RPMs – just slightly above normal idle range. So after washing it I took it for a short run and really stepped into it a couple of times, which may have helped it very slightly, but not altogether. Except for the rough idle @ 8/9K RPM range (only), it seems to run fine.
The truck has a little over 75000 miles on it (almost all freeway miles). I never tow and I drive it fairly easy, except I will blow it out about once every 500 miles. I always average about 20.5 to 21 MPG (hand calc)… one or two MPG less in winter. I always add PS or Redline fuel conditioner to every tank. I service the truck myself every 7K miles (oil, oil and fuel filter, and usually the air filter too. Truck is all stock. I’m suspicious I may be developing an injector issue because last winter it started becoming more difficult to start when cold (20F to 30F ranges). Once in a while it will put out a little white smoke at cold start in mornings – but not all the time. Dealer did the flash for white smoke in 2006. Any ideas? Does this sound like injectors?
Old 11-29-2009, 08:37 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
How in the world do you get that thing to turn 9,000 RPMs
Old 11-29-2009, 08:43 PM
Administrator/Jarhead
madhat's Avatar
That's what I was wondering!
Old 11-29-2009, 08:45 PM
Purplezr2's Avatar
I'm guessing he mean .8k-.9k rpms guys
Old 11-29-2009, 08:55 PM
Raspy's Avatar
It idles at 9,000 RPM?! What happens when he revs it?
Maybe it's not broken in yet at 750,000 miles.
Old 11-29-2009, 08:59 PM
iker42's Avatar
things probably cracking the foundation of every building it nears.....thats alot of R's
Old 11-29-2009, 09:27 PM
Mr Jerry's Avatar
**** that was funny.
Old 11-30-2009, 08:06 AM
Al Ex's Avatar
OK - 800 - 900 RPM... can anybody provide a little help? Can a problem injector(s) act up at only a specific RPM range this low, or is this something else?
Old 11-30-2009, 08:15 AM
madhat's Avatar
I would start cheap... fuel filters, and run some injector treatment. What is your fuel pressure?
Old 11-30-2009, 12:55 PM
SuperMuise's Avatar
IF your not using a chip like the adrenalin or a smarty, i would think its your injectors. "madhat" has the right idea, wash some injector cleaner through it and see if that does anything.
dieselcarpenter
04-07-2013 11:24 PM
Burning Oil
08-01-2010 04:09 PM
sawboywv1
25
06-30-2009 05:09 PM
banks twinram
12-16-2008 10:13 AM
Captain Dean
06-23-2006 10:22 PM
Quick Reply: Rough Idle @ 900 RPM Only – Please Help!
