Rod and Don M. did it again!!
Old 03-20-2004, 09:32 PM
mcevins's Avatar
Guys,
I finally got to dyno my 94' 12v and was quite pleased with the results. We used a Mustang 1750 load dyno and the results were:
490 H.P. @ 2520 rpm's
1123 Torque @ 2250 rpm's
Rod the QS B-1 and the Formula 1 injectors worked great. I really feel that tuning would get me a bit over 500 H.P. I don't understand why my peak power is at such a low RPM number when I have a 4,000 governer spring kit and 60lb springs. Nonetheless the 12v injectors from Don M. and the Turbo from Wildcat worked really well.
Thanks,
Meacham Evins
Old 03-20-2004, 09:50 PM
jigdog's Avatar
how are you ever going to get by with out that ten extra hoarses sounds really great.
Old 03-20-2004, 10:40 PM
SmokinDodge12V's Avatar
The cam has to do with at what rpm max power is the 4gsk and 60lb springs just help hold the power for a longer time.
Old 03-21-2004, 01:32 AM
dsljunkie's Avatar
What kind of EGTs are you seeing?
Nice numbers by the way
Scott
Old 03-21-2004, 01:49 AM
Jim Fulmer's Avatar
mcevins
Those are some darn inpressive numbers, dang I wish I was there, I'd tune that one for free....sometimes smiles are better than money......keep at it!
Jim
Old 03-21-2004, 02:18 AM
Push Rod's Avatar
Location: Drive till ya hit a Polar Bear, then go back 50 miles
Nice numbers Meach
Rod
Old 03-21-2004, 11:46 AM
DTR Advertiser
Don M's Avatar
Meach,
The 12 valve is cammed, stroked and most importantly "discharge curved" for a power band to be right where you made max power at.
With the load available with the 1750 Mustang you can make the power where you should.
Using a Dynojet where the rollers are lighter we see HP curves higher in the rpm band. Most guys tune for higher rpm power with timing, etc. I bet you could have made more HP with a more conservative timing set up.
Its too bad we cant pound the air into the engine at 2200rpm. HP would be very high compared to what we are doing now at 3000-3500.
Good numbers nonetheless
Don~
Old 03-21-2004, 09:48 PM
MTCUMMINSMAN's Avatar
mcevins,
Good numbers but I'm gonna catch you!
Chase
Old 03-21-2004, 10:39 PM
dodgeman01's Avatar
man I wish my truck had all that stuff. Well actually I just wish i had a working tranny right now but if I look outside my window all I see in my baby sitting on our 35' GN drag waiting to go to a buddys house so I can drop the tranny and see what little monster is makeing that nice hammering sound in the tranny right behind the imputshaft
DM01
Steven K
06-04-2009 10:32 AM
ddestruel
12-07-2008 06:37 AM
Badd Dogg Guy19
01-18-2008 09:19 PM
b84u
02-20-2006 01:04 PM
Sean S
11-15-2002 12:25 PM
Quick Reply: Rod and Don M. did it again!!
