rocker arm torque
rocker arm torque
Hi guys,
I pulled the cam and replaced the front engine mounting plate on this engine out of an '06, replaced the cam and am wondering what the torque spec is for the rocker bolts. Also I still have the front cover off and with 100,000 on the engine I think while I'm in there I should go ahead and do a valve lash check. Do I just line up the timing marks on the crank and cam gears to start the valve adjustment?
Thanks, gunnie
Thanks, gunnie
SilverSootXpres
10-07-2007 11:46 PM
