Roar and vibration
Old 05-15-2010, 12:51 PM
lehall's Avatar
Roar and vibration
Took it to shop ,they said it was front right wheel hub. They would repair for $600, but none available. So I did it myself for $300. First I checked diffy ,no problems. Still have roar. Can a U joint roar after 50 mph ? Everything runs fine till 50-70 then there is roar and vibration.Its been like this 3 weeks and is driving me crazy. Any help would be appreciated. Thanks
__________________
Old 05-15-2010, 01:46 PM
Ram Guy's Avatar
Tires can make a grouly sound if they are aggresive and starting to cup...Check that. Maybe it's time for a rotation.
Old 05-15-2010, 02:02 PM
lehall's Avatar
Thought of that
Tires rotated two weeks ago. Not the problem.
Old 05-15-2010, 08:54 PM
Jeff in TD's Avatar
Roar would be strange from a U joint I would think.
Carrier or pinion bearing maybe?
Old 05-15-2010, 09:04 PM
lehall's Avatar
Jeff
is there a carrier bearing on a one piece driveshaft ? Where is it located ? I'll change lub in rear diffy tomorrow.
Old 05-15-2010, 09:24 PM
grey ghost's Avatar
I have had the same prob. on my 06. I had an ABS light come on, had it checked and said left front wheel scensor. so I changed hub and light stayed on and vibration and sound hasnt gone away. I have noticed that when I had my wheels balanced it was 6 - 9 ounces out af balance scince the last balance and rotation which was only 2 months prior. I know that BFG has had bad batches of tires, and mine are around 8 months old. Discount said one of my wheels are bent ( MOTO METAL ) yep they were cheap. please keep us posted if you change anything else or if you find it.. Thanks, I will do the same.
Old 05-15-2010, 09:52 PM
Jeff in TD's Avatar
I meant the differential carrier bearings...
Old 05-16-2010, 10:36 AM
lehall's Avatar
Grey Ghost
Funny, I have BFG tires around 8 months old too. My problem is something else tho, you can feel almost grinding thru the steering wheel.
Old 05-16-2010, 11:03 AM
1985cucv's Avatar
caliper could be stuck on. get the truck rolling at 60 for a while pull over and feel around the front brakes maybe one is stuck slightly? if it is real hot you have an issue
Dodgezilla
04-25-2005 02:38 PM
bigbrowngoat
01-30-2005 03:45 PM
KenR
32
08-20-2004 11:23 AM
thatguy
08-04-2003 09:05 PM
KenR
36
05-18-2003 08:06 AM
Quick Reply: Roar and vibration
