Right front brake locking up
Old 01-21-2009, 06:03 PM
95black2615's Avatar
It's locking up at low speeds such as coming to a stop sign. There is also a squeaking noise from the same area that goes away when the brakes are applied.
A month ago I replaced the rear shoes and drums. Also replaced the front rotors and pads at the same time. I lubed all the pins and adjusters very well. I have had 1 ton chevy wheel cylinders for a couple of years already.
Sounds to me like the right front is hanging up while driving maybe?
Old 01-21-2009, 06:42 PM
infidel's Avatar
Could be a bad brake hose or bad caliper.
Old 01-21-2009, 07:08 PM
Might be the caliper.....I put a new/rebuilt one on that side about 1 1/2 years ago cause the bleeder was rusted in and broke off.
Anyway to diagnose a hose problem?
Old 01-21-2009, 07:14 PM
infidel's Avatar
Sometimes the hose will have a puffy looking spot on the outside.
What happens is the plys separate inside the hose and a flap hangs down making a one way valve that doesn't let the fluid bleed back when you let off the brake.
Old 01-22-2009, 02:51 AM
99 24v's Avatar
jack up that side and spin the wheel and see if it spins with resistance. break loose the brake hose on that side and see if it changes the drag being felt on the wheel. hope this helps.
Old 01-22-2009, 07:21 AM
patdaly's Avatar
Cheap as hoses are, replace them, I personally would do another caliper while I am in there.
Whole lot cheaper than if it ruins your rotor, not to mention much less work.
Old 01-22-2009, 12:58 PM
I'll check all that stuff out.
Should I look into a bad wheel bearing too? Would that cause something like this?
Old 01-22-2009, 02:13 PM
dozer12216's Avatar
Wheel bearings make noise more so than pulling. Prying the calipers out to replace pads got piston sticking. I recomend replacing both calipers at same time. My luck is two months later the other hangs up.
Vert
12-19-2013 07:42 PM
hulmule
03-10-2010 10:42 AM
seahawkdodge
05-12-2009 11:30 PM
00Dog
09-19-2006 05:21 AM
xp8103
12-25-2005 09:45 AM
Quick Reply: Right front brake locking up
