Ride-Rites and Hellwig sway bar?
Old May 6, 2007 | 11:08 PM
CTDinMT's Avatar
Anybody know if a Hellwig sway bar will fit my rear axle with Ride-Rite Air Springs on there? Shipping to Alaska is expensive, so I don't want to find out the hard way they won't fit! I e-mailed Hellwig but haven't gotten a response yet. Thanks!
Old May 6, 2007 | 11:44 PM
shortbed rv's Avatar
Try this thread;
https://www.dieseltruckresource.com/...d.php?t=146713
This thread shows an air spring and a rear sway bar. I just ordered the hellwig rear sway bar $235 including shiping. My superglide hitch bracket are in the way of using the u-bolt to hold the hanging brackets for the sway bar. I will have to find someone to weld the hanging brackets to the frame.
Old May 7, 2007 | 02:10 AM
53 willys's Avatar
I thought I read on here some where that a member took his hellwig off because it would not fit with his bags.....but I cant remember when or who it was????
Old May 7, 2007 | 06:48 AM
CTDinMT's Avatar
shortbed rv- That picture was worth 1k words! Thats what I needed to know. I also see that it clears the Mag-Hytecs. Good stuff! I have a slide-in camper, and I'm trying to tame the little bit of side to side swaying. Thanks much for the replies!
Old May 7, 2007 | 09:37 AM
AlCorr's Avatar
This is the Hellwig sway bar and Firestone air bags system. No problem at all. I believe the Ride Rite air bags are the same.
Old May 7, 2007 | 11:31 PM
XLR8R's Avatar
I installed the Firestones and the Helwig on the '05 - they fit fine together and work even better!
shortbed rv
May 23, 2007 09:21 PM
Agades
Feb 8, 2007 05:22 PM
DanTana
Apr 30, 2005 01:13 PM
RamRat
Nov 24, 2004 06:10 PM
BEHRMAN
May 4, 2004 12:09 PM
