Replacing struts - alignment required?
Old Nov 19, 2008 | 03:04 PM
truckjunkie's Avatar
I'm in the process of replacing the struts on the front of the Wife's Pathfinder. Is an alignment required after replacing struts?
Also - I'm getting a decent deal on Monroe Sensatracs - they're supposedly geared toward a smooth ride vs. firm ride, and that's what the Wife will want... And they have a lifetime warranty...
Thoughts?
Old Nov 19, 2008 | 06:31 PM
Number47's Avatar
monroe makes good stuff and i wouldnt get an alignment
Old Nov 20, 2008 | 02:34 AM
AlpineRAM's Avatar
I would get an alignment- simply because the vehicle has done enough miles to wear out the struts, and there could be some other stuff amiss. Your tire life and also a small part of the fuel economy depends on correct alignment.
Just my 2c
AlpineRAM
Old Nov 20, 2008 | 07:36 AM
1-2-3's Avatar
Just a plain ole guy
Most cars with struts use the bottom clamping action of the strut to set the camber. If you've taken one of them off, you should have allready seen this. Plus you'll never get the top back into the same spot, even though there is ver little play. Just r/r'ing the spring will make it sit diffrent. Definitley get an alignment.
whosdunit
Apr 28, 2010 10:18 PM
eightball
Apr 7, 2009 10:59 AM
capt.Ron
Apr 27, 2008 12:28 PM
MTGunNut
Nov 4, 2007 01:02 AM
