replacing sending unit
Old 12-05-2006, 05:40 AM
timmdavis's Avatar
2000 diesel 280,000 mi got the new sending unit in but all I get is air pumping thru. whats up?
Old 12-05-2006, 07:41 AM
TIMMY22's Avatar
you got a leak somewhere, check all connections first. more info on what happened?
Old 12-05-2006, 07:45 PM
timmdavis's Avatar
I replaced the sending unit in the fuel tank, put 5 gal of diesel back in tank, filled filter housing with diesel 2 or 3 times to prime yet i still get alot of air being pumped. I removed both supply and reture lines from tank and checked for sucktion and air, I have both. No start.......
Old 12-05-2006, 08:10 PM
TIMMY22's Avatar
why did you replace sending unit in the first place? no gauge reading? rotted elbows?
Old 12-05-2006, 08:22 PM
Racer9's Avatar
5 gallons may not be enough to fill the pick up, put another 5 in.
Old 12-06-2006, 07:38 AM
TIMMY22's Avatar
5 is enough. try disconecting the module,loosen and turn it left to right.
maybe the pickup line is hanging up on the side.
Old 12-06-2006, 04:57 PM
timmdavis's Avatar
I replaced it becuase I was getting an engine lite and lose of power when trying to maintain 35 or 45, had to pump accelerator once then power was restored. got tired of pumping the gas pedal. pump was just changed out at 250,000 mi and change the fuel filter ever 12000 mi.
Old 12-06-2006, 08:06 PM
Racer9's Avatar
I don't think your problem was the sending unit. All it does is tell you the fuel level. If you replaced the entire module, then the in tank pick-up should be OK, and you likely need new fuel lines. You're getting an air leak.
96_12V
13
10-20-2011 02:06 PM
SammyBuca
11-04-2002 09:17 AM
JASON T.
10-20-2002 01:53 PM
Quick Reply: replacing sending unit
