Replacement Headlights
Old 04-05-2006, 01:35 PM
HappyGA's Avatar
http://cgi.ebay.com/ebaymotors/94-01...53861686QQrdZ1
Saw these as I was breasing through, and wondered if anyone new anything about them. We all know that the srock lighting is mediocre at best.
Would like any input that yall may have.
Old 04-05-2006, 04:37 PM
casper_cobra's Avatar
i saw those yesterday...i wonder if they have the sport look with out the extra set of bulbs available
Old 04-05-2006, 05:06 PM
upersleder's Avatar
$45 to ship two headlights, they can stick them up ..............
Old 04-06-2006, 11:52 AM
Abbynormal's Avatar
I wonder what set of bulbs this lamp uses ? I take it its not the 9004 . I wonder about the wiring .
Old 04-06-2006, 03:24 PM
Gotlift01's Avatar
You'll have to do some modification to get them to fit. And the wiring is also and issue......there is a company that sells a plug and play harness but I can't remember the name for the life of me.....I'll do some searching and see if I can find it again.
But to answer your question.........YES they will help big time in the lighting department. I had a 99 sport with those headlights and they were great compared to the ones we have.
~Nick
Old 04-06-2006, 10:21 PM
willysrule's Avatar
those look like they only have one bulb inside....I think that is the reflection that makes it look like the sport style (two bulbs), if someone could say those were good quality I would order them right now, lighting is my only complaint about my truck…
Old 04-07-2006, 08:47 PM
willysrule's Avatar
anyone out there have a set of these???????
Old 04-07-2006, 09:34 PM
Abbynormal's Avatar
I emailed the seller some questions about the bulbs and wiring. Probably won't get a response till Monday, but when I do I'll post it here.
Old 04-07-2006, 10:46 PM
willysrule's Avatar
Thank you, I’ll be waiting…really hoping these are an easier upgrade than the sport conversion...
Old 04-10-2006, 06:36 PM
willysrule's Avatar
anything yet???
Old 04-10-2006, 08:58 PM
Abbynormal's Avatar
Nothing yet. I guess they gotta get over the weekend
Old 04-14-2006, 11:00 AM
maddog55's Avatar
Yes.
Two bulbs per headlight assembly on the sports lights. 9004 bulbs go in the inboard position of the assembly, 9007 bulbs go on the outboard position. both bulbs have hi/lo fillaments. I used aftermarket heavy high heat connectors to the bulbs, and 100/80 watt bulbs in all four positions. I can melt the snow on the ground in front of me ( a little exageration). Fit right in to the holes. Cut the factory headlight wires to use as trigers for relays you should buy. You can use two relays only, one for the 9007s and one for the 9004s. I chose to use four different relays , that is one for high beams on 9004s one for low beams on the 9004s, and the ame for the 9007s.
99 TDC, 4 SPEED manual, 4X4, 3.54 gears, ISSPRO pyro, boost, fuel pressure, AFE intake, Edge EZ box, 35 inch tires, and now, a cooked clutch. regular single 9004 bulb headlight assembly.
Regards,
the MADDOG
Alfdude1
02-13-2013 12:01 PM
jmarx82
12-28-2009 10:08 PM
Sidewinder
42
02-04-2008 02:36 PM
Extreme Diesel
40
12-25-2006 11:23 PM
Luckycharm1
11-18-2006 11:41 PM
Quick Reply: Replacement Headlights
