Replace Quick-Connect Fitting to LP
Old Oct 5, 2005 | 02:35 PM
billmac's Avatar
I want to replace the quick-connect hose from the tank to the LP. After doing several searches it looks to me like the hose ID is 3/8ths. Also, it looks like I will need a 4 foot section to go from the end of the metal line to the LP. The reason for doing this is so that I can use a regular hose clamp to avoid any possible air leaks at the quick-connect fitting. I looked at the labeling on the existing hose and it appears to be high pressure metric, but the size is not readable. Obviously I want to get a hose that is compatible with diesel fuel. I'm not sure about the Gates fuel line hoses; I know that the Goodyear Hysunite hose available at Summit Racing is ok but I don't need a 25 foot length. Also, is the fuel return hose the same size?
Old Oct 5, 2005 | 02:49 PM
Dr. Evil's Avatar
I used 5/16" hose (both were the same) on my 2001...No problems yet.
JKM
15
Jan 16, 2006 11:10 AM
SilverRam01
Jul 27, 2005 11:15 PM
chucktownsend5
Apr 3, 2005 07:53 AM
tony
Jan 11, 2005 10:44 AM
Falcon2005
Dec 13, 2004 10:49 PM
