How to remove the whole wipper arm?
Old 03-12-2004, 10:55 PM
KATOOM's Avatar
I'm trying to take off the wipper arms to check and maybe swap but I cant seem to get them off and I dont want to break or scratch something. The hood doesnt seem to open far enough and I cant seem to do it when its closed either. I see a little clip like retainer or something like that at the base but not sure what it is. Whats the trick? Thanks for the help.
Old 03-12-2004, 11:18 PM
Tfeore's Avatar
Try this, flip the wiper to 90*, pull the clip about 1/8" then pull the entire wiper assy. straight up.
let me know how this works out.
Old 03-13-2004, 08:35 AM
Commatoze's Avatar
Ditto on the above. Also if you can direct a squirt of WD-40 using the plastic tube around the joint, then tap gently it with a mallet, it'll help break the corrosion.
Old 03-13-2004, 10:54 PM
KATOOM's Avatar
Thanks, but I thought after looking at the way the hood opens I was under the impression I couldn't flip the wiper arm up to a 90*. But I will give it another try.
Old 03-13-2004, 10:56 PM
kingofdodge7131's Avatar
dont even have to take it up that far, just level it out and the pin will come out
Old 03-13-2004, 11:06 PM
Commatoze's Avatar
You can't, you have to lift the hood a little, but the post above is correct too.
Old 03-13-2004, 11:11 PM
Tfeore's Avatar
Katoom, sorry about the hood. I didn't look at your sig
Just looked at how mine appear to come off.
Old 03-14-2004, 12:18 AM
Haulin_in_Dixie's Avatar
They come off real easy with the hood off Wonder how I knew that
98silver12v
01-03-2009 01:05 AM
BigDan
07-08-2006 11:04 PM
PWT05Dodge
05-26-2006 06:45 PM
KATOOM
12-07-2003 08:20 PM
Quick Reply: How to remove the whole wipper arm?
