What relay is it?
Old 01-18-2010, 06:20 PM
hounddogks76's Avatar
What relay is it?
I found a relay below the steering column. It is in the junction where the wires from the turn signal switch and the wires from the ignition switch join together in the wiring harness by the steering column. Its a round metal relay . There are no numbers, just says made in Haiti.
Old 01-18-2010, 06:23 PM
Old-stuff's Avatar
It's probably the delay for the ignition key light.
It sounds like the timer for the ignition halo ring.
edit- looks like I am slow tonight...
Old 01-18-2010, 06:26 PM
jimbo486's Avatar
i'm guessing the ignition halo ring is only available on tilt wheel models regardless of year or being non-i/c or i/c?
Old 01-18-2010, 06:38 PM
It is a non tilt steering wheel......the reason I'm asking is I can't get my turn signals to work. Didn't know if that relay had anything to with it. I already changed the flasher relay and that didn't help. I have flashers, just no turn signals. I've deduced it to somewhere between the Turn signal switch and the ignition switch, the fuse is hot and I've traced and repaired all wires and splices.
Old 01-18-2010, 07:24 PM
jimbo486's Avatar
maybe change out the turn signal flasher. the flashers and turn signals are on separate circuits. you said you repaired all wires and splices but, is the fuse good or blown?
Old 01-18-2010, 07:56 PM
2stroke's Avatar
yes. there are 2 flashers under the dash.
Old 01-18-2010, 08:47 PM
B-North's Avatar
I was pulling some gross old wiring from under the dash yesterday and noticed this relay got pretty warm when the door was open and cooled down when it was closed. So I think it is for the dome and map light.
Old 01-18-2010, 10:13 PM
first4age's Avatar
If you find the repair, please post.
My turn signal went out during a trip to Death Valley on Thanksgiving!!!. I've been today lazy to trace it down but with the rainy weather for the next week or so in the Bay Area, I decided today is the day since people's driving skill drops to half when it rains.
I have a similar problem. My hazard works but my turn signal doesn't.
According to my 1997 Service Manual, it does have a 'Turn Signal Flaser'. The wires going into the flasher is BK (Black) & RD/GY (Red/Grey).
Old 01-19-2010, 08:03 AM
Hmmmm......I thought the turn signal and hazards were in the same flasher. I'm waiting for my FSM to arrive in the mail from Geno's! There was another white plastic relay next to Hazard relay in the fuse panel?
Old 01-19-2010, 09:11 AM
Old-stuff's Avatar
wiring
Hounddog
there are wiring diagrams in the "sticky" for a 93. They appear to be pretty much the same as my 90,except for a couple of color differences. Check those out, they will help 'til the FSM arrives..
Yes, there are separate flashers for turn and hazard. they're on the fuze block on my 90. Just swap the two around and see if your flashers still work.
Ray
ps.Wow Dave! three minutes late! Well, you are getting older.
Old 01-19-2010, 09:23 AM
Hey, thanks ray, I'm gonna swap them right now to see if that works!
Old 01-19-2010, 09:37 AM
The plugs are different on the 2 relays....have to wait for the woman to pick me one up town. And yes the fuse is good.
Old 01-19-2010, 09:57 AM
unixcowboy's Avatar
Is it the 'key-in-ignition' buzzer ??
Seems to me it hangs under the dash somewhere.
mazeppa
02-10-2004 06:54 PM
Maccandy
06-02-2003 08:30 PM
Jack Thorpe
04-18-2003 01:26 PM
Neal C.
01-12-2003 11:08 AM
tomsauto
12-28-2002 08:57 AM
Quick Reply: What relay is it?
