Is a regulator needed when using a piston pump?
Old Apr 12, 2008 | 03:29 PM
Elohim1's Avatar
Or can you just use the 2nd gen. piston pump without a regulator?
Old Apr 12, 2008 | 03:38 PM
dpuckett's Avatar
If you use the 2ndGen piston pump you need a regulator. If you use the low pressure piston pump (Cummins #3936320), no. The VE doesnt like more than about 18-20psi max.
Daniel
sinthome
Oct 17, 2013 06:57 PM
GIT-R-DONE
Aug 24, 2011 10:27 PM
BurrisWill
May 29, 2009 12:58 AM
dieselJon
Aug 29, 2007 10:41 AM
CTD99
13
Aug 23, 2005 10:55 PM
