Regen cycle
If your truck is stock, it's been in a regen. Usually an active regen is every 400-500 miles though it differs depending on how you drive, your truck setup (transmission, rear gears, cab and bed configuration, tire size, etc), and the loads you pull. You aren't supposed to be able to tell when your truck is going into active regeneration. In the 22000 miles that my DPF was on the truck, i couldn't have told when exactly it went into active regeneration a single time. It did, though. ALOT. So is yours.
The only way I knew I was regenning was by watching the OH mileage start to drop for no apparent reason. If you never reset your OH then you probably would not see a real difference. I reset mine with each fillup....
skeeterboy
08-03-2007 06:43 PM
