Refineing The Steering system
Old 02-07-2009, 02:07 AM
Torque master's Avatar
Question Refineing The Steering system
I wonder what research or current options there our for us to refine the Steering system to make it as much of a Racken Pinion type of Senario , As to when I am driving at high speed passing in a straight away I would like the steering to respond more controlled less wander, ( Tighter ) in one since, more responsive I would guess best refines what im looking for. I currently have already installed a DSS Steering Stabilizer, along with my current 4.5 inch Fabtech Lift Kit, I also installed a Don Thuren Steering Stabilizer Bar in the Front of the Truck, And also his stainless steel End Links, And a Borgenson Steering Shaft , I am going to See if this Can be adjusted for a Tighter Steering Fill.
Would this Steering Stabilizer upgrded Bar from thuren Fabrication act as a Sway Bar basically. Iterested in the development of the next level of more controlled Steering system.
Old 02-07-2009, 08:00 AM
38short's Avatar
What the scoop Bra??? You talking about your 05???How many miles , maybe your steering box need looking at..
Old 02-07-2009, 12:52 PM
cbrahs's Avatar
bigger tires are not helping you at all
RiverRat2
10-15-2019 10:59 AM
Erska
08-27-2008 08:07 PM
13ALPHA
07-08-2008 11:31 PM
EClancy
11-15-2005 03:48 PM
Quick Reply: Refineing The Steering system
