Recalibrating Speedo
I am taking my truck in to flash ECM and I want to have the speedo calibrated but I am not sure what the pinion factor should be and I want to double check what they tell me it should be. I have 315/70-17 tires and 3.73 gears on my truck, does anyone know the number that should be used?
I believe, depending on your year, they can only go so high. I have an 06 and they can only go to a 285 size ratio max. You may find your speedo still off but better. For my 285/70/17 that factor is 636. If you have a programmer like the Triple Dog or Smarty you can correct the full amount.
woodsRIDER92
07-24-2010 11:00 PM
cvcook
06-25-2010 03:25 AM
mrdrinksalil
07-16-2009 09:18 AM
aggie06
07-12-2008 05:55 PM
