rebuilt tranny wont go forward!
Old 12-08-2008, 01:25 AM
gladesauce7's Avatar
Can anybody think of anything i could have done wrong? reverse works perfect i know i didnt tare a seal i just am puzzled about this.
Old 12-08-2008, 08:06 AM
j-fox's Avatar
There are so many possibles it isn't easy.
did you disassemble the VB? Are all the check ***** in and in the right places?
Did the rear clutch get put together correct?
Are you planning on doing a pressure check?
Old 12-08-2008, 10:41 AM
it has a goearand valve body and tc that was in it before i broke my input shaft. i didn't mess with vb. i just pulled the clutches apart and put new steels and clutches in. but i put the one piece input in so on that piston i put new seals in i dont understand what i did.
Old 12-08-2008, 02:36 PM
dozer12216's Avatar
Look at your failed input shaft and note there are three sealing rings (one larger and on rear retainer)on it. Did you put three on yours??
Old 12-08-2008, 02:50 PM
mikmaze's Avatar
did ya make sure its fulo? will show full on stick, then ya run it and fill up the converter/ passages..... check er in neutral to be sure.
Old 12-09-2008, 01:06 AM
yea i'm not sure what's going on today i pulled it out of the garage and it worked perfect again didn't have time to mess with it or take it for a test drive but it was holding solid in the drive way as in spun the tires on wet concrete before it didnt even move so i will mess around with it 2mro ill let ya know whats going on !
Old 12-09-2008, 06:54 AM
j-fox's Avatar
Pressure test it.
oneofthefewbmx
10-01-2007 12:58 AM
abc4yew
27
07-04-2006 09:15 PM
Quick Reply: rebuilt tranny wont go forward!
