Rebuilt HX35w is this nut OK?
Old 07-20-2010, 01:05 PM
Walt L's Avatar
Hi I just got a new rebuilt HX35w and I not sure I like the condition of the exhaust fan nut. it appears to be a 12 point style nut but about 3 of those point are ground off on one side and a bit less ground off on the opposite side of the nut. Is this done to balance the shaft? Also why is 1 vain on the inlet and outlet fans painted white? It has no perceptable in/out play but has the basic up/down movement of about 3/32nd buy eye. Mainly, whats up with the nut grind?
THANKS
Old 07-20-2010, 05:05 PM
gorms's Avatar
The "nut" on the back of the shaft should be part of the shaft assembly, including the turbine wheel and shaft, front to back. Sounds like that's how they balanced it. The paint marks should be to index the compressor wheel to the turbine (exhaust) wheel/shaft.
Old 07-20-2010, 08:42 PM
scottsjeeprolet's Avatar
the white mark is probably a reference point they used to balance turbine. The grind marks are also how they remove material to balance it.
Old 07-20-2010, 09:26 PM
Crazy_Farmer's Avatar
Like everyones mentioned, its the grinding done to balance it. Just imagine how fast its spinning! Should be fine, my stocker has it, as does a hx40 I have sitting in the shop.
Old 07-21-2010, 12:41 PM
Walt L's Avatar
Thanks guys,
Now I'll feel better putting this on the truck. I'm always a little worried when I take a chance on a E-bay buy on a unit reputedly rebuilt buy an outfit called D&W Diesel. A big Garret turbo shop. I got the unit for $411 shipped. From what Iv read, this is supposed to be a straight up drop in job...hopefully thats the case.
Thanks again for responding.
wisconative
05-13-2013 07:20 AM
Clane
06-02-2012 03:31 PM
Rales
08-08-2003 12:59 AM
Quick Reply: Rebuilt HX35w is this nut OK?
