Rearend walking with new 35 Toyos
Old 06-20-2009, 07:54 PM
Bounty Hunter's Avatar
Just put the 35x12.50x17 Toyo M/Ts with 2" spacers on (DRW) and at highway speeds, if you bump the steering wheel one way or the other the rearend kinda sashshays(sp?). Is this just something you have to get used to or will it get better after they wear in. Only about 22 miles on them and at 55psi. I think the wife would be too scared to drive right now. Any thoughts?
Also would it be a good idea to install a Rancho steering stabilizer to replace the one from the factory?
Old 06-20-2009, 08:36 PM
mikmaze's Avatar
new tire squish, the tall deep lugs are flexing and thats what ya feel, as you get used to it it will get better and wear down a bit. you can try changing the tire pressure to see if you find a sweet spot.
Old 06-20-2009, 10:27 PM
Spooler's Avatar
Even my truck with standard size tires did this when I had them replaced with Goodyear Road Armors. It took about 1,000 miles to get them to act right. It was a pain in the tail and I hated it.
Old 06-20-2009, 11:31 PM
Howy's Avatar
Yep, totally normal for me too on my Toyo MT's. I think after a good 500-1000 miles everything was normal and broke in.
Good luck and enjoy.
Old 06-21-2009, 01:04 AM
dslpwr81's Avatar
I'm probably wrong here, but instead of it being the tread, isn't it the big increase in the side wall height? Doesn't it just have more flex to it and takes longer to recover from the sway?
Old 06-21-2009, 09:09 PM
Thanks for the replies.
How do ya'll feel about the steering stabilizer? I am willing to do it if it will make the tires last longer.
Old 06-22-2009, 11:06 AM
gsbrockman's Avatar
Originally Posted by mikmaze
new tire squish
aka "tread squirm"
Old 06-22-2009, 02:11 PM
Ram Daddy's Avatar
It can`t hurt to install one...but it`s not going to make your tires last longer...and it won`t take the "squish" out either.
Old 06-22-2009, 04:58 PM
nelrod's Avatar
I had same experience as Howy, my new nitto terra grapplers did what you are describing for first thousand or so.
Old 06-22-2009, 05:02 PM
LFD2037's Avatar
My neighbor had this w/the Terra's. It was absolutely rediculous! Felt VERY dangerous. He runs an auto repair shop & checked out everything on the truck thinking something serious was broke. He too k them back & got different tires.
4CEFED
03-25-2011 12:54 PM
NewbieDavid
03-05-2007 02:28 PM
roberts11260
13
01-28-2007 03:00 AM
westcoaster
07-20-2004 07:47 PM
C-Chaplain
35
06-22-2004 10:04 AM
Quick Reply: Rearend walking with new 35 Toyos
