Rear Springs
Old 10-18-2009, 11:04 PM
rdut's Avatar
Rear Springs
Hi All
Will 1 ton, 3500, springs bolt into my 2500 with out modification?? Also is there a difference between dully and single wheel springs?
Old 10-19-2009, 08:29 AM
Pickin on the wrong admin...
Diesel Dave2's Avatar
I'm pretty sure the springs are wider on a 3500.
Old 10-19-2009, 07:57 PM
Clarkkent's Avatar
They should swap provided they are both 3" wide. some light duty trucks were 2.5" wide rear springs.
kent
Old 10-19-2009, 09:05 PM
2500superram's Avatar
my truck has the 3" leaf's,your's might too
Old 10-20-2009, 12:43 PM
sjester's Avatar
All the #8800 and up springs are 3 inches wide both 2500 and 3500. If you can't find a set of one ton springs there is alway the add a leaf option. Just did that on mine, not much diff in the ride
Old 10-21-2009, 09:03 PM
rdut's Avatar
I read on here one time that the 1 ton springs actually ride better then the 3/4 ton. Can anyone verify this?
Jordan5687
01-29-2015 10:32 AM
Polaraco
10-28-2008 09:34 PM
53 willys
23
05-19-2008 06:14 PM
95turbo4wd
12-12-2007 05:59 PM
bigred496
10-22-2004 07:16 PM
Quick Reply: Rear Springs
