Rear rotor removal
Old 06-17-2008, 11:34 AM
na4now's Avatar
Rear rotor removal
One of my right, rear pads let loose, and tore up my rotor. Anyone know how to remove it, so I can install a new one? Ive searched and cant find anything.
Old 06-17-2008, 12:31 PM
rich's Avatar
yea you have to unbolt the axle end and pull it out to get the rotor offf its real easy
Old 06-17-2008, 12:52 PM
na4now's Avatar
Can you go into more detail, please?
I slapped on some pads for now, but they wont last with this ate up rotor.
Old 06-17-2008, 05:45 PM
HIGHGEAR's Avatar
Jack it up and take the tire off. At the rotor where the stud sticks out, you might find 3 or 4 thin locking washers, take a chisel or something to cut them off. Spray some kind of power lube where the rotor is touching the hub. From the back side tap on it with a hammer working your way around the rotor so that your not cocking it. I know with mine it was a PITA because it's a snug fit plus it was rusted, but it will come off. If this doesn't work, pull the axle and hub assy. and go have it pressed off. Also make sure you spray power lube around the studs as well. Hope this helps.
Old 06-18-2008, 01:57 AM
dbossdiesel's Avatar
If you're lucky like I was the rotor will just slide off after you remove the caliper and bracket first that is! And just a reminder. don't forget to release the E brake first! A buddy of mine did that and I had to samck him up-side his head before he realized what he did! LMAO!!! Good luck! If you get stuck just come back and ask! I'm sure we've all been there!
Old 09-26-2009, 12:01 PM
JOE M's Avatar
I just did mine and the only thing I did different was I went around the lug area with my acetylene torch. Just a little heating made them let loose from the hub.
ChrisG
03-25-2009 02:40 PM
robbynne
02-04-2009 08:39 PM
Steverfd
06-24-2007 10:21 PM
Mototrout
06-10-2006 11:19 PM
hotdram
02-25-2006 05:42 PM
Quick Reply: Rear rotor removal
