rear pumpkin gasket
Old 04-11-2011, 07:48 PM
mike1788's Avatar
rear pumpkin gasket
realized today that i have a small leak in my rear pumpkin. called for a price on a part from napa, they said theres was a reusable gasket.
im wondering, are these what the trucks come with from the factory? if so, i can just clean mine up and replace it right? TIA
Old 04-11-2011, 08:06 PM
Hvytrkmech's Avatar
They do come with a reusable rubber gasket and they normally do not leak. You can pull the cover, clean everything up and inspect the gasket for any tears or damage. If there is no damage reuse it.
Old 04-11-2011, 09:48 PM
rockcrawler304's Avatar
^^^^ This.
I forget the torque specs, but it's not a lot. Be careful when tightening the bolts.
Old 04-12-2011, 11:07 AM
Just a plain ole guy
1-2-3's Avatar
silicone
Old 04-12-2011, 12:23 PM
randallp84's Avatar
Originally Posted by 1-2-3
silicone
X2. Silicone works great in this application.
Old 04-12-2011, 09:11 PM
Dirk5.9's Avatar
I believe the torque specs are 25-30 ft. lbs.....
Old 04-13-2011, 10:50 AM
lastcall190's Avatar
+1 I just reused mine as well...
FWIW specs are 30ft-lbs as per the Service Manual. I torqued mine in a pattern similar to torquing a wheel and all is well.
-J
iker42
10-30-2005 01:32 AM
Scotty
10-14-2005 06:49 PM
miketriton
06-02-2004 06:43 AM
Quick Reply: rear pumpkin gasket
