rear main seal
Old 10-07-2011, 09:46 AM
mrclean's Avatar
rear main seal
I have a new clutch to install in my truck, so with 200k on it, I figure I should replace the rear main seal. I checked the service manual, and it says to put it in dry........is this correct? I've always put a little oil on seals when replacing them, although I've never done one in a Cummins.
As an aside, I've read in the past about a cooling system mod that installs on the back of the head. If it's going to be done, it seems it would be a good time to do it while the trans is out. Is that mod actually beneficial?
Old 10-07-2011, 06:14 PM
Tate's Avatar
Follow the FSM directions. Make sure its clean in dry if you change it. Personally, if its not leaking, I'd leave it alone. It could go a long way without leaking. You may look into putting a speedi-sleeve in if your crank has a groove worn into it.
Old 10-13-2011, 12:56 PM
mrclean's Avatar
Thanks Tate.....just seemed odd not to lube it for the install, but I'll go with it. It is seeping a bit, and since I'll be in there anyway it seems like replacement is a good idea. FSM says if it's grooved, the seal can go in another 1/8", but if it's bad I'll sleeve it.
ted_pulliam
08-04-2010 11:33 AM
bnold
07-07-2007 06:18 PM
chaikwa
03-24-2004 09:23 PM
okcummins
12-21-2003 07:45 PM
Mostwanted
09-17-2003 06:55 AM
Quick Reply: rear main seal
