Rear leaf removal?
Old 08-25-2007, 12:27 PM
goodeyesniper75's Avatar
Rear leaf removal?
Would it be possable to take out one or more leafs from the rear springs to get a little softer ride? Would it be worth the effort or would it have adverse effects?
Old 08-25-2007, 12:44 PM
Pooter's Avatar
Alot of guys take out the overload spring(bottom of the pack big fat spring)
BUT you lose load capacity.
I have a set of Carli mini packs I need to install(removes the overload, replaces it with a 5 pack) Should improve the ride quite a bit. Im just waiting on this dang heat to die down before I even start on it
If you do pull the overload, and tow heavy, get a set of airbags...
Old 08-25-2007, 12:49 PM
Will it be noticable better ride? if so how much towing cap. do you think i would loose?
Old 08-25-2007, 12:56 PM
Pooter's Avatar
With just pulling the overload, or going with a mini pack?
From what I hear, the mini pack improves the ride quite a bit! But the BEST way to get a good ride is full replacements(Carli/Lorenz/Thuren/Kore)etc
If you go with full replacements, get some airbags if you tow heavy.
As far as how much capacity you loose, I couldnt tell you a number
Just think though, whenever you load up, and its on the overloads, when they arent there, itll be sagging big time!
Old 08-25-2007, 01:08 PM
Would you recommend just pulling the overload and not replacing it? maybe just a spacer or somthing?
Old 08-25-2007, 01:15 PM
Pooter's Avatar
I wouldnt, but that doesnt mean you couldnt.
Id go with a mini pack(that replaces the overload anyway), or full replacements from any of the Big four(Thuren/Carli/Lorenz/Kore)
If you do either get a mini pack setup, or full replacements, id get some airbags if you tow more than 8k~ lbs
I dont see a small car trailer with a 3-4k lb car on it being a big deal, but towing heavier and youll be riding on the bump stops(unless you get bags)
Just my .02, im sure some guys will come along with some better advice(having done it already to tell you the ride quality)
Old 08-25-2007, 01:48 PM
sounds good, i would like to see if anyone has just take it out with no replacment. A guy by me just put in a mini pack this week so i want to see how his rides....
Old 08-25-2007, 01:58 PM
firemansdiesel's Avatar
The rear mini leafs will take the bite out of expansion joints and indulations (speed bumps and pot holes) for the most part. The full leafs will make it feel like you never went over rougher roads and etc. Remember the full leafs you will lose some of the factory towing capacity. They are made to ride rather than tow. You will need air bags if you tow heavy w/ the full leafs. Lorenz springs which are different than the rest (they are not Deaver) has removable bump stops to tow factory specs. You will still need air bags like stock to get some sagging out.
Old 08-25-2007, 02:05 PM
bob4x4's Avatar
Carli was the first I think building a dual stage full leaf pack,he also has a std full leaf pack and of course the mini pack.You will not lose any wt capacity using the mini or full dual stage.The dual stage with long travel air bags does it all! Here is what it looks like articulated off road.
Bob
Allways_Lost's Avatar
Would this drop the back end?
Like a cheap way of lowering it?
Old 08-25-2007, 02:15 PM
abc4yew's Avatar
Bob that spring pak and air bag set up looks great...nice articulation...I want one!!ks
Old 08-26-2007, 11:44 AM
so overall removing the bottom leaf with no replacment is not a good idea?
Old 08-26-2007, 12:37 PM
UnrulyNFS's Avatar
I'm gonna try it this week probably. I'll let you know. If your gonna tow heavy with it, definately get airbags. I never tow, just sled pull and I'll need some blocks or bags to do that again.
Old 08-26-2007, 02:28 PM
Lsufan78's Avatar
sniper, i love my carli mini packs!! i did a little write up on mine when i installed them.
Old 08-26-2007, 02:33 PM
Lsufan78's Avatar
https://www.dieseltruckresource.com/...d.php?t=141891
Quick Reply: Rear leaf removal?
