Rear/front diff question
Old Oct 20, 2006 | 07:52 PM
Royboy Ft,Sask's Avatar
Does anyone know if my 2005 Dodge/ Diesel front and rear diff come with
synthetic oil ? and if so would it be identified some where?
Old Oct 20, 2006 | 08:02 PM
CTDinMT's Avatar
Yes, all AA&M axles come fron the factory with synthetic 75W-90 in them. I have no idea what brand gear oil it is, but it is syn. Welcome to DTR, by the way!
Old Oct 20, 2006 | 11:15 PM
five20too's Avatar
I have seen alot of people in here recommend Mobil 1 Synthetic for the diffs but I was in Oreilley's today and all they had was Quaker State full syn. Anybody have any dealings with this or should I just stick with Mobil 1?
Old Oct 20, 2006 | 11:48 PM
WUnderwood's Avatar
I put Royal Purple full synthetic in mine, no probs
Old Oct 20, 2006 | 11:50 PM
Strjock81's Avatar
You can also order Amsoil, Redline, etc. off the net and get along very well with it. I am currently running Amsoil 75w-140 Severe Gear since pretty much every mile my truck drives is towing, and so far so good. I have an Amsoil Commercian acct. however, which makes it about 2/3 the price off of the shelf Mobil 1, which is also a fine oil.
Old Oct 21, 2006 | 12:21 AM
CTDinMT's Avatar
I run Amsoil Severe Gear 75W90. It's too cold up here in AK to run the 75-140.
Old Oct 21, 2006 | 01:02 AM
ptgarcia's Avatar
Do the limited slip equipped axles require a friction modifier?
Old Oct 21, 2006 | 01:09 AM
TexasCTD's Avatar
No, the AAM LS axles do not need friction modifier. I believe the older Dana axles on 2nd gens did, but DC says not to add it to the 3rd gens.
Old Oct 21, 2006 | 01:10 AM
TexasCTD's Avatar
You can run any synthetic GL-5 rated 75W90 or 75W140 gear oil and be fine. If you want to run Mobil 1, you can get it at Autozone, if they have one near by you. I use Mobil 1 75w90 and have had no probs.
Old Oct 21, 2006 | 01:12 AM
ptgarcia's Avatar
Thank you.
Old Oct 21, 2006 | 04:09 PM
five20too's Avatar
Thanks TexasCTD. I forgot about them. I should start calling them Oil Zone because of a great selection compared to others!
Old Oct 22, 2006 | 02:25 AM
TexasCTD's Avatar
Actually, I usually refer to them as "GhettoZone" . But at least they have what I want even if I do have to go to 2 or 3 different ghettos to get it all.
You and Pauly are both very welcome. Im just glad to be able to chime in and help out sometime. Changing out the diffs is just as easy or easier than changing the oil, although I had never done it until I got my current truck.
afate45
Jun 7, 2014 12:08 AM
Bowser50
33
Jul 21, 2013 06:33 PM
banana
Dec 1, 2009 11:44 PM
lucey
Jun 20, 2005 09:02 AM
shaft
13
Jan 29, 2004 07:37 AM
