Rear Diff ?
Old Feb 5, 2005 | 04:40 PM
roadie00's Avatar
Rear Diff ?
Just finished (I Think) changing the fluid in the rear diff. I drained the old stuff (it was nasty) put it all back together and started putting the new Mobil 1 75-90 synthetic back in. I only got a little over 3 quarts in before it started coming out of the fill hole... Does this sound like it was enough fluid? I took a little bit out to get it 1/4 inch below the fill hole.
Thanks in advance!
Old Feb 5, 2005 | 04:57 PM
tony's Avatar
Check your glove box for the size differential, given your truck specs I'm thinking the 10½". The fluid capacity is:
10½" - 4.75 pints
11½" - 7.65 pints
Good luck!
Old Feb 5, 2005 | 05:11 PM
roadie00's Avatar
It's a 10.5 rear end...
If my conversion is correct -
4.75 Pints = 2.375 Quarts
I'll check the level again to make sure it's good. I will probably need to take a little more out...
Thanks for the help!
Old Feb 5, 2005 | 06:02 PM
bulabula's Avatar
Roadie, if you filled it to the hole you're good to go.
If you absolutely feel the need to remove some oil, pull the plug for a few minutes and let the fluid find the level at the bottom of the hole.
FWIW, my little 9.25" front diff took 2.75 quarts, so your "little over 3 quarts" doesn't sound wrong for a 10.5". The book values are "nominal".
Filling diff's ain't rocket science.
Old Feb 6, 2005 | 12:43 AM
Hemi Cat's Avatar
The full mark is the bottom of the check plug hole, always.
Old Feb 6, 2005 | 01:42 AM
MonkeyLips's Avatar
According to the manual, the oil level should be 1/4" below the drain hole, + or - 1/4". In other words, the level should be 0" to 1/2" below the drain hole, so you are right in the middle. I fill mine up just until the oil starts dribbling out a little, then put the plug back in...good to go.
Old Feb 6, 2005 | 08:02 AM
roadie00's Avatar
Thanks for the advice everyone. I'll check it and add a little to get it to the fill hole. Thanks again!
afate45
Jun 7, 2014 12:08 AM
banana
Dec 1, 2009 11:44 PM
papaduck
Apr 4, 2003 09:29 PM
46mech
Mar 8, 2003 07:43 PM
USMC64-70
Nov 10, 2002 02:59 PM
