Rear Diff Fuid change
Old 09-08-2003, 12:38 PM
t6_man's Avatar
When changing the rear fluid, if I am on level ground, can I just drain and refill? It seems that I read, in some past threads, that I need to raise each side of the truck after filling to get the axles filled. Is this necessary? If so, do I need to do the same thing when draining in order to get all the old fluid out? Thanks...
Old 09-08-2003, 12:44 PM
Commatoze's Avatar
Re:Rear Diff Fuid change
Yes, It's advisable to hike up each side so the axle tubes thoroughly drain. Another way would be to leave it drain overnight, and refill the next day.
Old 09-09-2003, 05:43 AM
t6_man's Avatar
Thanks Commatoze
Old 09-10-2003, 11:14 AM
silver_goat's Avatar
Can you overfill the Diff's with to much fluid? Topped mine off just enough to feel the fluid just below the drain plug.
Old 09-10-2003, 12:26 PM
Crabjoe's Avatar
I don't think you can overfill a diff as there is a breather hole.
banana
12-01-2009 11:44 PM
dieselfumes57
09-09-2008 12:47 PM
92DIESEL
05-01-2007 08:00 PM
65fury
03-18-2007 09:19 AM
hellotbone
06-20-2003 09:21 AM
Quick Reply: Rear Diff Fuid change
