Rear diff fill
On your truck there may be a "fill line" stamped on the rear cover. If you didn't know to look for it, it would be easy to miss. The full line is about 3/4" below the bottom of the fill hole.
Rubber gasket is reuseable. Spec is 24 ft/lbs plug and 30 ft/lbs cover bolts, but several people have snapped off cover bolts using a torque wrench to that setting, so I'd probably go 25 or so, or good and snug with a 3/8 drive ratchet.
banana
12-01-2009 11:44 PM
grishfish
07-04-2007 07:07 PM
Bad Ramer Jamer
12-25-2005 11:13 PM
Original Junior
02-16-2005 09:24 PM
