rear axle widths???
Old 07-01-2007, 04:59 PM
smknram's Avatar
rear axle widths???
Is a dana 80 out of a single rear wheel and a dana 80 out of a dually the same width? Im having thoughts of converting mine to single if it will be the right width.
Old 07-01-2007, 05:44 PM
Registered
blackdiesel's Avatar
nope, the dually is 5" wider
Old 07-01-2007, 07:26 PM
slim51015's Avatar
http://dodgeram.org/tech/specs/axle/286RBI_specs.html
Read the 5th line up from the bottom.
Old 07-01-2007, 08:30 PM
Registered
A 3500 cab & chassis is the same as the 2500, the dually is 2 1/2 inches wider on each side. trust me
Old 07-01-2007, 11:01 PM
smknram's Avatar
well even if it is only 2 1/2" wider on each side then with a set of 16x10's and some 315's you probably wouldnt notice it too quick would you?
Old 07-01-2007, 11:10 PM
Bobcat698's Avatar
I ran an d80 out of a dually on my truck for a bit, tires only stuck out a tad more in the rear, about even with front tires.
Old 07-01-2007, 11:16 PM
smknram's Avatar
ok thanks for the help guys, has anyone ever messed with taking the dually fenders off and doing a little body work or am i better off finding a regular bed?
Old 07-02-2007, 06:57 AM
Registered
Originally Posted by saab9k
mine is a regular dually ( was ) don't see a problem with the difference.
you have a flat bed on your truck.
Old 07-02-2007, 07:02 AM
Registered
there's a big chunk cut out of the fender, so the tires will clear when loaded. It wouldn't be a little body work
nvr-enuf
01-30-2014 06:56 PM
Ilikebikes
0
12-10-2009 01:19 PM
kruegerlouie
03-02-2009 03:13 AM
kiszka6911
08-22-2006 11:21 AM
MX429
08-20-2006 06:41 PM
Quick Reply: rear axle widths???
