Rear axle seal - can't find a lot of info?
So I have a stuck driver's rear caliper on my truck, which has 137K on it. I put rear pads and rotors of somewhere around 100K. The caliper stuck, dragged, and cooked the pads and cracked the rotor.
Upon pulling the rear brakes apart I found two disturbing things.
1 - the passenger parking shoes were separated.
2 - the driver's side axle seal is leaking. I don't know if that's what caused the issue, or if the grossly overheated brakes warped or damaged the axle seal.
So I need to replace the axle seal on that side, but can't find any info on a SRW truck on the site. Am I looking in the wrong place? Is this an uncommon problem? Am I doing something wrong? Auto Zone doesn't stock the seals; btw, so I have to find somebody who has one.
https://www.dieseltruckresource.com/...e-t229836.html
NATIONAL Part # 710564 Oil Seal; Fluoroelastomer Seal, Shaft Size=2.854", Housing Bore=3.877, Outer Diameter=3.878, Width=0.59in
Rear Wheel; Inner
$19.63
Add to Cart
SKF Part # 28540 {#05086773AB, 5086773AB} Width=.590"; Outside diameter=3.8780"; Bore=3.877"; Shaft=2.854IN
Rear
$21.99
Add to Cart
From www.rockauto.com
Rear Wheel; Inner
$19.63
Add to Cart
Rear
$21.99
Add to Cart
07_Ram
03-19-2012 02:23 PM
notpowerSTROKIN
11-18-2007 11:43 PM
subspd
05-20-2007 10:15 PM
kawi600
32
10-17-2006 08:12 AM
