Rear Axle assy.
Old 08-21-2003, 02:32 PM
Mr. Jimmy's Avatar
Rear Axle assy.
As many of you may know I have had trouble with the 11.5 AAM axle and it was rebuilt by the dealer, after rebuild the noise is worse, so I finally convinced Service manager to order a new Axle assy. on the 11th of Aug. I am being told this order is a vehicle off road order to speed up delivery, but after 1.5 weeks parts dept still doesn't have a estimated time of arrival date. Has anyone here had their axle replaced and how long does it take to get one? I sure am missing my 99 CTD right now
Old 08-22-2003, 05:26 PM
spots's Avatar
Re:Rear Axle assy.
2003 I got mine replaced in Jan took 2 days Michigan had 4 in stock they flew it in?? (I saw the airport tags on it). Works perfectly now...(dare I say that???)
Old 08-25-2003, 09:06 AM
Mr. Jimmy's Avatar
Re:Rear Axle assy.
Called the 800 number for Dodge this am and was told that the axle is being released today, should be here in 3 days. I think this may have been a ******* problem more so than a Dodge issue. Dodge Rep wouldn't tell me when the ******* ordered the axle, I think that it probably wasn't on order two weeks ago as I was told, imagine that!
Old 08-25-2003, 09:42 AM
DODGE4X4's Avatar
Re:Rear Axle assy.
Hey my Dad's truck is a 03-2500 4x4 CTD. He has been saying that when he makes a turn his rear end is making a grinding or a grabing sound. Is this the noise you are talking about? He took it into Dodge and they didn't fix the problem. :'(
Old 08-25-2003, 11:08 AM
Mr. Jimmy's Avatar
Re:Rear Axle assy.
My problem is a Ring And Pinion gear that whines or howls at certain speeds due to incorrect R&P setup.
Old 08-25-2003, 05:26 PM
sawboywv1's Avatar
Re:Rear Axle assy.
dodge4x4 if pops has a limited slip rear on his new truck than that is what he is feeling! mine is serious for traction multiplied by the small factory skins.
Old 08-25-2003, 05:28 PM
spots's Avatar
Re:Rear Axle assy.
[quote author=DODGE4X4 link=board=20;threadid=18698;start=0#msg176401 date=1061822534]
[/quote]
That grabbing seems to be the normal activity of the "new" Americal Axle. Mine does it also. Worse backing up. But it does hook up at the jobsite and get me outa there at 5pm. ;D
AggiePhil
13
10-09-2019 09:28 AM
Rob_OBX
15
02-21-2007 06:36 AM
McGyver
09-08-2004 11:14 AM
Mark Thomas
08-14-2004 06:27 PM
Quick Reply: Rear Axle assy.
