really weird noise twice today from 3250DDD?
Old 08-15-2008, 08:42 PM
jmccart's Avatar
I have been meaning to adjust the rod so the clutch grabs sooner in the clutch travel (not so close to the floor). Today, while cruising in a parking lot, while pushing the pedal down deep to the floor, it made this loud grinding/squealing noise. I felt it in the pedal big-time. Then it did it again while parking at work.
What the heck?
Any ideas?
I did take the 30 seconds to lengthen the rod a few minutes ago.
Thanx.
Old 08-16-2008, 10:00 AM
PourinDiesel's Avatar
Clutch being dis-engaged too far.
Old 08-16-2008, 11:22 AM
jmccart's Avatar
Thanx. Does the way I explained it make sense? I thought about that but it seems backwards. I had the rod too short, and it was not shifting easy, so I really had to push the pedal down far. It seems that if it was that way, I could not be getting the pedal down too far.
Before I did not have the lil' plastic switch for the "no-start-w/o-clutch-depressed" thingy.
Thanx for the help PourinDiesel!
Old 08-17-2008, 07:40 PM
beaver76's Avatar
With my 3250 the clutch engages at the top of the pedal travel. When I push the pedal in the clutch sounds like brakes that are metal to metal. Is that what it sounds like?
Old 08-18-2008, 01:08 AM
jmccart's Avatar
That is exactly what it sounds like.
Old 08-18-2008, 10:28 AM
Topper1's Avatar
Sounds to me like your fork is hitting the outside if your clutch housing.
Old 08-18-2008, 01:18 PM
jmccart's Avatar
It has not happened again since I adjusted the rod to be longer.
Old 08-18-2008, 04:35 PM
beaver76's Avatar
Mine has sounded like that from the first time I pushed the pedal in. I just thought the dual disks made that type of noise.
Old 08-20-2008, 03:45 PM
Topper1's Avatar
That's not a good sound! Your actually hitting the clutch body with your clutch fork. Adjustments are needed.
Old 08-20-2008, 08:47 PM
beaver76's Avatar
OH OH! I have adjusted the clutch pedal rod out quite a bit and the noise is stll there. If I go in farther with the rod then the nuetral saftey switch will not engage. should I adjust the pedal out farther? Please Help you have me worried now.
Old 08-21-2008, 01:03 PM
Hintz's Avatar
Mines making that noise to, dumb question but how do you adjust the rod? Wheres it located?
Old 08-21-2008, 01:05 PM
RD TRCTR's Avatar
Did y'all remove the washer from behind the fork pivot ball? The pivot ball threads into the transmission and a wahser/ spacer is placed between it and the transmission.
Old 08-21-2008, 01:08 PM
jmccart's Avatar
If you have t he hydraulic upgrade, it is the rod that goes from the new master in the firewall to the back of the clutch pedal.
Old 08-21-2008, 01:32 PM
jmccart's Avatar
I don't know. I was a one armed man for a while and had to have a shop do it. The guy who did it is a truck trans. shop.
Old 08-21-2008, 11:12 PM
beaver76's Avatar
No I didn't mess with the pivot ball at all. There was nothing in the instructions that said anything about that. How much damage am I doing to the clutch?
Quick Reply: really weird noise twice today from 3250DDD?
