PDA
View Full Version : Who is ready for a sled pull
coreydr2003
01-20-2008, 10:03 PM
Ok guys time to start thinking about that 300' mark. I have a date set for the 24th of May
Where?? right here in Ole Houston/Raymondville.
This year should be great I'm tryin to git the dyno down from Floor It and there will be all kinds of classes hopefuly some tractors too.
I'm thinking about havin after the pull, Back to Back pulls and some dirt drags hope all of you guys can make it or at least some of you.
It would also be a great G2G for the chapter,( PistolWhipt help me out here) I know the dyno is a plus for that.
Lets here It[laugh][laugh]
Ground Shaker
01-20-2008, 10:28 PM
I WANT WHISKEY!!!!
Oops, I'll keep that subject to my thread... LOL
coreydr2003
01-20-2008, 10:37 PM
I WANT WHISKEY!!!!
Yeah you better.
This year there not goin to care so much, they just ask for anyone running a truck to wait tell your done on the track
Ground Shaker
01-20-2008, 10:47 PM
But as of the moment I don't plan on having a truck there!!!! Yes!!! Can you say "pregame on the drive there!!!!"
Editors Note: I'm not a drunk, I just love alch!!!!!
PistolWhipt
01-22-2008, 08:06 AM
GS .... You're a SPAZ !!!
This sounds like a great time !! May is plenty of time to mark the date on the calendars and plan days off !! Coreydr2003 .... fire me a pm with the details when you can, please.
Cheers,
PISTOL
Gear Jammer
01-22-2008, 08:40 AM
I'm just up the road in Wright County, where is this pull in Raymondsville?
coreydr2003
01-22-2008, 10:11 AM
Its at there fair grounds, go threw houston (north) on 63 hwy and take B hwy to Raymondville.Once in Raymondville 137 goes back left, take a Right stay on B and the fair grounds are on the right. What part of wright Co you from???
coreydr2003
01-22-2008, 10:16 AM
Cheers,
PISTOL
You bet I will, I have some kinks to work out and then I'll drop that to ya. Beings your so close hope you can make it this time.
I'v pulled in Mt Grove before, your turn to come to one of mine ha ha [laugh]
puffsmokeonya
01-22-2008, 01:51 PM
if i get a clutch i will prob pull....... oh yes and tires
Gear Jammer
01-22-2008, 02:22 PM
Hartville.
coreydr2003
01-22-2008, 03:32 PM
Hartville.
Well I'll be we're almost cousins!! J/K . Your right on the back door. I come threw there alot going to springfield
Gear Jammer
01-22-2008, 04:14 PM
I have several buddies with diesels, a good mix of strokes, max's, and cummins. I will spread the word about the pull, is this a sanctioned pull by association or just something you are throwing together. Yeah we aren't far away at all.
coreydr2003
01-22-2008, 05:08 PM
No sanction but I aways have a set of rules, to make things fair. We try to follow the DHRA rules there has been some changes with DHRA so we will see how things work out.Ill hve the sled from MHTTPA here and there whole sanction but the diesels will be my rules. Yeah please spread the word. This will be the 5th pull I,m hosting here.
Tree DR
01-22-2008, 06:48 PM
Man that's a long way offfff. I went to a pull today. I had to pull the kids around on the sled. Not with my truck though. I'll get those ladder bars and weight rack put on you and Sat volunteered then I'll pull.
coreydr2003
01-22-2008, 09:16 PM
Its a long ways off but It will be on your mind I know, as for the wait rack and ladders I'll drop by some time let you look at them even leave my rack with you if you need. Wish I could help but I don't have time to work on my own I still need to pull the cam, head and clutch not sure when I can do this busy, busy. I'll do what I can thought.
Gear Jammer
01-23-2008, 08:18 AM
Yeah my buddy pulled with the DHRA last year so those rules aren't hard to follow. I am curious to see what they change though with the new people.
Tree DR
01-23-2008, 09:35 PM
So how many HP do you have to have to tear something up? I need to stay just below the tear something up HP. I got to have this truck every day to work with. No down time allowed. I want to pull just not tear it up.
cumminsdriver635
01-23-2008, 10:11 PM
You can break something stock if you try hard enough.
Gear Jammer
01-24-2008, 07:35 AM
x2........
Tree DR
01-24-2008, 11:03 AM
So if I can pull loads in and out of pastures and barn yards that weigh 34k and not tear anything up, what kind of HP does it take to kill a SB COFE or a drive line? I figure the motor should be ok just the parts around it could be problematic.
Gear Jammer
01-24-2008, 01:18 PM
(34K) is that gross or just what is on the trailer?
Tree DR
01-24-2008, 02:17 PM
Average gross 34k. 39k several times and 42k heaviest. Got in and out of some vary easy to tear something up situations.
Gear Jammer
01-24-2008, 03:02 PM
42K is a helluva load. Hauling logs or what? I don't think I would reccomend that every day. Do you have a scale ticket for that? That would be one to frame. [laugh]
Tree DR
01-25-2008, 08:07 AM
I might be able to find the ticket. Nope didn't do it every day that's was the exception. Normall load 34k. Truck and trailer about 15k load 20k. Stock tran and clutch for about 100k no problem with clutch 5th gear not would come off and had to put them back on. Trying to get in and out of barn yards was the fun part. Slideing backward down a icy driveway was fun didn't jacknife it. Put it in reverse and went about 50yds to the bottom and just grazed the fence on one side, only 26k gross though. Lots of other fun stuff too.
Gear Jammer
01-25-2008, 08:33 AM
How many bales you talking? I had 390 on a 32' earlier this year. It was straw though. [duhhh] They averaged around 45 lb. apiece though. Wire tied, tight bales. I had roughly 17,550 on the trailer.
Tree DR
01-25-2008, 05:52 PM
Only about 260 bales at about 75 lbs each. 300mi loaded from Eastern KS to Northern AR through the Branson hills. Pulled those hill at 45mph. 97 with 3.55 gear little extra fuel and 16cm no wastegate exhaust on turbo straight piped. Made a little noise, but it sure pulled good. Never had a pyro on it so who knows how hot it was getting. I was pulling 4 loads a week for about 2 mo's a year. Did that for about 3yrs with 2 different 97's.
Tree DR
01-27-2008, 09:07 PM
So what HP could I pull with and not break the drive train? Drive shaft would be my biggest concern. Anyone got a set of 3/4 ton stock tires and rims I could use to pull with. Can't tear up my dually tires.
Gear Jammer
01-28-2008, 08:18 AM
so 19,500 worth of hay. Not bad! How does that come up to 42K? I must have mis read some earlier posts.
hoffdog
02-01-2008, 02:10 PM
I was talking to a guy in town today and he said that several of the missouri pulling associations voted in to have diesel classes, is this correct? He mentioned Mid-Missouri and Southern Missouri anyone know if this is right?
Ground Shaker
02-01-2008, 02:42 PM
From what I understand, yes. I hear most are going to work in conjuction with the Show Me Smokers Series, though details are still being worked out at this time but these assoc will be working with/running with the smokers plus the smokers having their own pulls. Alot is going on with the smokers, I think things are only going to get better in the state of MO thanks to them.
Gear Jammer
02-05-2008, 08:54 AM
Yeah I heard Southern Missouri is going to have them.
Tree DR
02-05-2008, 04:41 PM
That was the average load. Bales were a little heavier some loads and I added a few some times for the customer. 42k was the heaviest. My brother actually scaled 49k but went back and unloaded some.
What's that hp level I need to be looking for?
Anyone got a set of 3/4ton take off tires and rims?
Ground Shaker
02-07-2008, 10:55 AM
Is it still the 24th? Just wondering cause that is going to be a heavy hitting time with Indy the weekend afterwards. Plus there is another large pull the weekend after. Just figured I would update this post since you guys were talking about Indy.
coreydr2003
02-07-2008, 06:48 PM
Is it still the 24th? Just wondering cause that is going to be a heavy hitting time with Indy the weekend afterwards. Plus there is another large pull the weekend after. Just figured I would update this post since you guys were talking about Indy.Yes its a done deal the 24th of May we will have a truck pull,.
Shaker I know this is a hot time but the way I see it , this will be a good time to get those trucks out of the shop and do some test and tuning. Plus looks like Show- me Smokers will have this pull just need that last nail drove. Is it risky? yes it is!! Do we love pressure? yes we do!! Do we love to pull, Hell yeah!!! Its ok Trucks will show and It will all be good[laugh][laugh]
Ground Shaker
02-07-2008, 08:07 PM
I can see those few weeks for us are going to be absolutely nutz....
coreydr2003
02-07-2008, 08:58 PM
Ya but Indy is going to be a blast for me cuz this is the first year how long do i get my rooms for Shaker
Tree DR
02-08-2008, 06:07 AM
I saw one thread where a guy booked a room when he left Indy last year and they told him they didn't have enough rooms for him to stay there recently. I'm guessing you might have to stay a few miles out to find a room or just take a sleeping bag and use the 8ft bed that will be with you.
puffsmokeonya
02-08-2008, 07:59 AM
i have done this. if you take an air mattress its nice. also take a tarp with lots of bungie straps for a roof lol
Bad-Duvall
02-08-2008, 09:14 AM
On what side is the event on the north side of indy? or where i have no idea
Ground Shaker
02-08-2008, 11:44 AM
I was told the same, did the same thing, but I'm getting a room now. I'm staying the 30 and 31 and leaving the first. Most will be traveling up the afternoon of the 30.
I got one of those notices but have found a few ways around it.
Ground Shaker
02-08-2008, 11:46 AM
SW side of town. Heading east from St Louis its before even the airport on 70.
Tree DR
02-08-2008, 07:39 PM
You need a co driver, I think I'll go just because I want to. I wouldn't expect you to find a room for me. I know how to sleep in a truck. Last time I went with Luken and paid half the fuel cost.
Ground Shaker
02-09-2008, 11:00 PM
We will see. If I have no little lady you got shotgun no problem. I'm getting a double bed hotel room so you got a bed if you need it at the moment. or we could get a cot to the room as well. Eitehr way, we cna find a place for ya to sleep. That wouldnt be a problem.
Tree DR
02-10-2008, 05:53 AM
Little lady besides your not my type. I had to say it because someone else would have. We'll what is that 3mo. away I'm sure you could find a woman by then well maybe 3 or 4 do I get to pick the one that goes along...
Ground Shaker
02-10-2008, 12:46 PM
I got heck from Corey and Matt for having a litle lady over last night...[laugh] I haven't had a drink in over a week and they are busting on me for having a little lady over..... I can't win![duhhh][laugh]
But sure, if you want to choose, or find me more, go nutz. I'm coming over to Nixa at some point in the next few days to look at a new piston. I'll give you a call.
Tree DR
02-10-2008, 09:05 PM
And you didn't even call and see if I wanted to party. Talk about left out. When your over this way Corey why don't you stop by and let me see that weight rack on your truck.
coreydr2003
02-11-2008, 09:02 AM
you got it man !!!!!!!!!!!!!!!!!!!
Tree DR
02-11-2008, 12:52 PM
Och!!!!!! Kick a guy while he's down.
With the ice were having here I won't be down long I'll be in the top of the trees that are left standing.
Ground Shaker
02-11-2008, 01:25 PM
Once i dig out of all this ice, I'll call ya darren. Looks like its going to be a good week for you!
PistolWhipt
02-24-2008, 07:29 AM
BUMP ...... Just haven't seen any new info on this topic for a while. Anything going on with this ... or has the ice & cold put a damper on everyones spirits ??
Cheers,
PISTOL
Tree DR
02-24-2008, 05:32 PM
I have been to sled pull/pushes the last couple of weeks, where were you all anyway?
puffsmokeonya
02-25-2008, 11:04 AM
when is the next truck pull no one tells me these things. or maybe i just dont ask.
Tree DR
02-26-2008, 07:44 AM
I truck pull every day 4k trailer +load? The track to the dump has been kind of wet lately haven't got stuck or it would be a real truck pull.
I haven't even looked at the real pull schedule yet. I'm not sure there are any around here in March though?
I'm still looking for a set of 3/4ton take offs like what your bro probably has/had for me to pull with.
puffsmokeonya
02-26-2008, 07:54 AM
ive got my pullin truck tires on my dodge right now. it rubs a little. my other tires went bald for some odd reason.
Ground Shaker
02-26-2008, 09:05 AM
Hey puff, any word on that Edge box of mine?
gunmetal02
02-26-2008, 09:33 AM
I'm ready for one but still have some stuff to do to my truck yet..
puffsmokeonya
02-26-2008, 07:08 PM
im gonna give you some money @ the next pull we are @.
