View Full Version : Ready to install moog springs!! SHould I get spacers as well?
jesussaves
11-18-2009, 12:43 PM
I bought the moog coil spring and i was wondering if I should get the daystar spacers as well. I dont want it higher in the fron than the back? Anyone have pics with or without?
ouchman
11-18-2009, 03:59 PM
http://www.dieseltruckresource.com/dev/showpost.php?p=2632033&postcount=12
PapeCAT
11-18-2009, 04:08 PM
http://www.dieseltruckresource.com/dev/showpost.php?p=2632038&postcount=13
TIMMY22
11-18-2009, 04:40 PM
I used the coil spacers and the longer shocks. Works great!
Just get the front end lined up on a 4 wheel alignment machine after you are done.
adam greene
11-18-2009, 06:11 PM
which spacers did you get in the sticky someone used chevy one and someone else used 94 up spacers.
adam greene
11-18-2009, 06:12 PM
anyone got a pic of the spacers used
SOOT4BRAINS
11-18-2009, 07:07 PM
I just put on 7226S springs on my truck without any spacers, and it raised the front WAY up. It sits level with the back now, very happy with them. I would say if you want it level, just do the springs.
TIMMY22
11-18-2009, 09:02 PM
I left the stock springs and bought the spacers and shocks from the part #'s listed in the sticky. Just type the part # into google and tons of places show up to buy them.
From Ouchman's post, here are the #'s
Daystar spacers #KG09101BK- stock springs - shocks #FTS-9119
jesussaves
11-19-2009, 06:03 AM
I just bought the 7226 I wonder what the difference is compared to the 7226s?
SOOT4BRAINS
11-19-2009, 11:48 AM
S on the end stands for severe duty. I think they are just a little stiffer. I got them in hopes they will not sag under the weight of the cummins. I imagine they will wear out and sag some day, but a long time from now I hope. I am very impressed with the ride. They feel stiff, but on the same bumps these springs move more than the stock springs. Not sure how that works, but its MUCH better than before.
C Pierce
11-19-2009, 01:32 PM
When I installed the 7226s springs on my truck it raised the front so much that I had to add 1 1/2 inch blocks in the back to level it out and it too about 3 or 4 years before the front end started to drop again. This time I'll just add the 2 inch spacers.
