reading Codes in Cab
Old 04-25-2006, 07:12 PM
megamac's Avatar
Does anyone know if the 1999 have the ability to get the OBDII codes in the cab? Or, do I need to buy one (yes I know I can get codes read at the parts store). Which readers are worth the money?
Thanks,
Bob
Old 04-25-2006, 07:14 PM
phox_mulder's Avatar
You'll need to get one, or keep frequenting the Auto Parts store.
Key on/off trick doesn't work on 98's or 99's.
phox
Old 04-25-2006, 07:15 PM
megamac's Avatar
****, I was afraid of that. Any good readers you can recommend?
Old 04-25-2006, 07:18 PM
I've heard that most of the off-the-shelf readers don't always play well with our dual computer trucks
(PCM and ECM fighting with each other)
You could always get the Smarty, have a code reader made for our trucks, and a little kick in the pants to go along with it.
phox
Old 04-25-2006, 07:33 PM
megamac's Avatar
Thanks,
I'll check into the Smarty....
Obo
Old 04-26-2006, 01:03 PM
RenegadeT's Avatar
phox
what years does the on/off trick work...and what's the exact procedure?
Old 04-26-2006, 03:14 PM
Registered
blackdiesel's Avatar
RenegadeT- it works on all the 24v 00, 01, and 02. and the sequence is on off on off on. then check the odometer and it will come up with the pcu (maybe pcm, or ecu, or ecm i forget) then it will say DONE. but wait a few seconds longer, the ecm will come up and read the codes on that. (again, not sure on the ecm part). then it will say DONE again. then your finished.
Old 04-26-2006, 03:15 PM
Registered
Originally Posted by megamac
Thanks,
Obo
definetly worth the 650 bucks. it reads codes, programs for larger tires, and is a very nice hp box.
Old 04-26-2006, 09:51 PM
piperca's Avatar
Actron works well.
mullishacrew
03-18-2012 12:41 PM
exwrestler
02-05-2010 09:34 AM
sallyman1
08-26-2008 06:20 PM
mbenedict
07-21-2007 09:19 PM
bendaj
02-02-2003 04:07 PM
Quick Reply: reading Codes in Cab
