Rattle in floorboard
Old 11-08-2006, 12:13 AM
gabbyfan's Avatar
When going over bumps, especially around 30 mph i can feel a rattle in the drivers side floorboard. Any ideas as to what would cause this? Thanks
Old 11-08-2006, 12:29 AM
kawi600's Avatar
Id ckeck for loose shock mounts, loose track bar. Bounce up and down on the fender you should be able to see the shock mount moving around if thats loose. The trackbar shouldnt budge when the wheels are turned from stop to stop.
Old 11-08-2006, 08:45 AM
JKM
JKM's Avatar
check for midgits with hammers hanging from the frame rail
Loose lower shock bolts have been known to make noise too , they need to be TIGHT.
Old 11-08-2006, 11:21 AM
hamilton71801's Avatar
I had the same rattle and it took the impact wrench on the shock mount bolts to fix it.
Old 11-08-2006, 03:35 PM
01RAMer's Avatar
I had rattles and it turned out to be loose plastic pop rivets holding the wheel wells. I found a 3rd party on the internet and got 100 for $20.00 bucks. Installed new ones and it cured the rattle. Don't go the Dodge because they want $2.50 a piece for them.
Old 11-08-2006, 08:32 PM
rockwithjason's Avatar
also check the steering column bushings.
Old 11-08-2006, 09:55 PM
gabbyfan's Avatar
Sure enough i tightened the shock mounting bolts and problem solved. Thanks for all the help i really appreciate it.
Old 11-20-2006, 05:40 PM
tpilgrim's Avatar
shock housing welds
I have rattling too but mine is the shock housing welds. Busted when it was bottomed out b4 I bought it.
t8ter
07-05-2006 10:47 PM
justagoodolboy
06-22-2006 06:00 PM
dodgediesel4x4
03-08-2005 06:06 PM
LarryJ
01-11-2005 07:10 PM
2k1yzfr1
13
12-03-2004 09:43 PM
Quick Reply: Rattle in floorboard
