Rattle coming from shifting linkage.
Old 03-06-2010, 11:08 AM
mstep3's Avatar
I've got a annoying rattle coming from the shifting linkage for transfer case. I checked right below the shifter underneath truck & the bushing seems to be worn out where the shifter connects to the shifting linkage. I tried using some oil on it at first case it was making squeak noise, but now it just rattles...The truck is an 02' with auto trans.
Do you guys know if these bushings can be replaced. I've heard others complain about these shifting linkages causing rattling & squeaking noises.
I couldn't really find any place online that might sell this kind of replacement parts......
Old 03-06-2010, 05:58 PM
mstep3's Avatar
I found this TSB on the 2001 models.
I was wondering if anybody has had experience with this problem?
21-12-00 Tapping/knocking sound during idle.
This bulletin applies to vehicles built before May 10, 2000, equipped with an automatic transmission. A tapping/knocking sound may be heard or felt in the driver side floor pan area during idle conditions. With the engine running at an idle, listen for knocking sound coming form the driver side floor pan area. If a tapping/knocking sound can be heard, replace the shift linkage with revised parts.
Old 03-07-2010, 10:08 AM
infidel's Avatar
http://dodgeram.info/tsb/1997/21-12-97.htm
Old 03-07-2010, 01:28 PM
mstep3's Avatar
Originally Posted by infidel
thanks. that's basically the same problem i'm having with mine even though it's an 02. Looks like people have been able to fix it with some extra rubber washers to keep it from wiggling.
Old 03-08-2010, 12:25 PM
justme-'s Avatar
and yes the bushings can be replaced. Worn out mine once already.
Old 03-08-2010, 09:57 PM
rodney cantrell's Avatar
My 95 is doing the same thing. I can hold the 4 wheel drive shifter back and it stops. I'd be interested in how you fix it. I'll try the rubber washers.
Old 03-09-2010, 09:47 AM
infidel's Avatar
I first tried the tab bending fix in the link above but the buzz came back.
Ended up doing the spring fix described at the top of this page http://dodgeram.org/tech/transmission/shifter_noise.htm
No problem for at least 10 years. I used a generic hardware store spring rather than the exhaust spring, think it was less than a buck.
Old 08-22-2010, 10:26 PM
taneum's Avatar
Anyone have luck with any of these fixes?
I have the 4WD shift lever rattle on my 1996 and its driving me crazy
GIT-R-DONE
03-25-2013 06:33 PM
mstep3
10-25-2010 12:26 AM
Gbuilders
05-08-2007 02:20 PM
Timberman
09-15-2006 08:15 PM
Quick Reply: Rattle coming from shifting linkage.
