Raptor 100, drop the tank?
Old 01-28-2008, 01:27 PM
jmccart's Avatar
For the Raptor 100, what is the install scoop on that badboy? Is it something that one can just connect to their existing lines from the tank?
Old 01-28-2008, 01:29 PM
06CTDforAU's Avatar
You still have to drop the tank. I contacted Charlie (aka Fuel Preperator) and he said that dropping the tank was still necessary. I guess that means it really is necessary.
Old 01-28-2008, 01:32 PM
jmccart's Avatar
Thanx 06CTD. I am getting worried that I will not get a shop to remove my bed & do the AD150 right. I was supposed to get it this weekend, didn't happen. And I can't take my 4.4/Smarty off level 9, or I will cry.
Old 01-28-2008, 01:36 PM
06CTDforAU's Avatar
Definately understand. Have you thought about using the Jeep canister? I know it's a relatively new idea, but it seems to work great and you don't have to worry about the 1/4 tank fuel issues. I've got a Walbro 392 and that is the problem I'm currently having. When I get close to a 1/4 tank, the crank times get long and the pressure jumps around. Slam on the brakes hard and it can (and will ) kill the engine. I'm going to try the Jeep canister and see what happens.
Old 01-28-2008, 01:41 PM
jmccart's Avatar
I guess I should read on it again. That thread got so long I stopped looking at it. I did get the Vulcan custom draw straw like 53 ****** used. It has seemed to work great for him.
Thanx.
Old 01-28-2008, 01:46 PM
06CTDforAU's Avatar
Thanx.
Check out the newest thread posted on the Jeep canister. The guy put some pics in there. Looks like a great idea to me. I also read 53 ****** thread and he done a great job. If I were to do it again, I'd either remove the bed or install the Jeep canister.
Old 01-28-2008, 03:13 PM
trik396's Avatar
You can also drop the tank instead of removing the bed...
Old 01-28-2008, 03:28 PM
06CTDforAU's Avatar
That's what I did when I installed the GDP kit. However, if I were to do it over again I'd remove the bed because it's only like six bolts and I have access to overhead cranes. I just feel that it would be easier than dropping the tank -- or for me at least. Plus, you could easily install the draw straw and know that it is perfectly set up in the tank. Either way works good though.
Old 01-28-2008, 11:26 PM
53 willys's Avatar
just to clear up a few things...the raptor100 should be able to go in without removing the bed or tank on the earlier trucks with OUT the intank pumps....since your truck is a 06 you WILL have to drop the tank or pull the bed.
I dont have ANY problems with stumbling or dieing....but I do get really erratic readings when the tank gets low....it bugs me enough now that I think I will try the jeep canister or maybe save the cash and gut the stock canister then use my vulcan drawstraw by installing it in the canister.....I am a little worried about the 150 sucking it dry tho.....so I may run the AD return line into the canister...but I am afraid the AD would get noisy from sucking the air and fuel it just separated back up.....I will let you guys know how it goes after I get the canister re-installed...
dodgerdog
02-23-2009 10:54 AM
53 willys
38
11-06-2008 11:18 AM
preloader
06-12-2008 07:40 PM
Dwitt0187
28
01-23-2008 07:32 PM
84mphcdt
16
12-19-2007 11:31 AM
Quick Reply: Raptor 100, drop the tank?
